Windshield Gasket too small
#31
The installer I used is highly recommended by both the local dealer and the indy that services my cars.
Looks like I am using Andy's workaround until the next rock bounces off the windshield, and I fly boomboomthump out for a weekend on the water and glass fitting.
#32
INTMD8 you are welcome as well
#33
I'm good with that! By that time I will have at least done it twice. I put in new front/rear glass last year and then this year decided to strip the car to bare metal for repaint. Going to reinstall soon.
#34
Not sure what aftermarket windshields installer is talking about.
Do you have part numbers for the glass and gasket you ordered?
I used 993-541-111-06 Windshield and 993-541-435-01 Windshield Gasket, which worked perfectly on my 993.
#35
Just wanted to confirm that OEM 993 windshield comes with channel for the gasket attached to the glass from the factory.
Andy
#37
Ah, that's right. I forgot I replaced both gaskets and indeed used "993-541-925-00 Windshield Gasket" as well.
#38
That's the part number I have as well.
Played around with some rope caulk, and a 1/4" fits nicely in the gap, and allows the gasket to sit flush on the pillar. Will backfill it a little with roofing caulk. It won't be long before a rock ruins this windshield. If you drive the highways in Mass the stone and gravel symphony off your car is a constant.
