Starter Tool Set
Starter Tool Set
looking to get a starter mechanics tool set. I'm between these 2 craftsman:
Metric ONLY:
http://www.sears.com/craftsman-172-p...4&blockType=G4
-3 quick-release ratchets
-8 extension bars
-20 combination wrenches
-109 sockets
-20 hex keys
-Magnetic bit holder
-10 screwdriver bits
Standard & Metric Combo:
http://www.sears.com/craftsman-230-p...1&blockType=G1
Includes:
-quick-release ratchets in 1/4, 3/8 and 1/2 inch drives, with 116 sockets in both metric and standard measures and 6 and 12 point
-Two extension bars
-Six combination wrenches in standard and metric
-Magnetic handle with 12 nut drivers, inch and metric, and 50 screwdriver bits
-40 hex keys
Any opinions on which is better to get? Thanks guys!
Metric ONLY:
-8 extension bars
-109 sockets
-20 hex keys
Includes:
-Two extension bars
-40 hex keys
I think the method of acquiring tools is a pretty personal decision that gets learned just from doing. When I started wrenching on cars, I bought one of those "all-in-one" kits like you posted, and as I had projects that used different pieces, I found myself pretty disappointed in the quality or usability. So I switched to just buying the pieces as I needed them. For example, I bought a nice individual 80 tooth ratchet and some normal SAE and Metric sockets and ratcheting box ends. Then I as I grew in need, pick up what you need from a quality manufacturer. Like deep sockets, impact sockets, wobbly extensions, 12-points, etc. Its more expensive technique, but you get quality pieces that will likely outlive you.
The all metric set would be better for working on the 993 specifically but the combo set would be better if you plan on working on anything else like older American cars, or other things like your lawn mower or other power equipment. Unfortunately the combo set is lacking in box end/open end wrenches which are critical for working on Porsche's in which access to fasteners is often very limited.
I think I would be looking at the combo set and expand it with some box end/open end wrench sets right away.
I would not be concerned about getting the number of pieces as much as the maker of the quality tool pieces. No need to go Snap On but would look for a higher quality tool than Sears today. Sears used to make quality tools at one point but not anymore.
Sure they still replace broken tools, but I'd rather have the quality without the hassle and inconvenience of returning.
I've purchased USED Proto, Mac, Snap-on, Bluepoint, and other quality brand-name tools on eBay in building my tool set. I,e.,Tap & die, allen head sockets, torque wrenches...
I go to Harbor Freight for normally expensive, one time use tools.
https://www.harborfreight.com/hand-t...set-62664.html
Similiar price point with same quality, IMHO.
Now that Black and Decker bought Craftsman, maybe they will elevate them back to what they used to be. So what do Rennlisters consider better, but not quite Snap on ? (just curious)
Like others have said get a set like that for base and realize that you will be adding to it.
SJW, a Carin' kinda guy
I would go all metric. Lowes has better tools than craftsman, but all of the mass market stuff is junk now (back in 2000 kobalt from lowes was made by the same people as snap on and I love those and my old craftsman are good too). I have 99% of what I need, but if I were you I would buy old craftsman or kobalt (or better) off craigslist.
JH Williams is under the snap on umbrella and is about 1/4 the price. They used to make kobalt.
Also, get a very good set (two sets are better) of Allen head sockets.
Keep in mind, in all probability, no matter what you buy, the tool you need, you won't have and will have to stop and go find it. I've been wrenching on cars for well over 50 years and, even now, I'm still buying tools.
Go for the metric only set. It looks pretty good with both 6 and 12points sockets.
For the price of $121, you can't even get a socket set from Snap-on.
Unless you have $$$, the Snap-On equivalent of that metric set is for sure >>$1000.
As you gain more experience/skills, you will know which pieces to swap out for the Snap-On. And they WILL be worth it!
It's not just the tool set, but also the user. You jank and crank, you're gonna damage things. I did all my maintenances and top end rebuild using a Craftsmen tool set. And, yes, I did eventually get a Snap-On wrench set with the bitey-thingy feature. It never fail to latch and bite into the bolt/nut that I am removing. OF course, you learn how to position the wrench and know when to back off the pressure.
Stop by Harbor Freight for all kinds of inexpensive ideas. A toy store for grown men!
One of the hand tools I found is best purchased as Snap-On or Craftsman are flair (brake) fitting wrenches. The inexpensive ones have heads that flex and will distort tight fittings before they pop loose.
I particularly like Harbor Freight's hand impact driver to break loose stuck screws.
Other may have differing opinions but I like their medium size torque wrench for wheel mounting
They have an outstanding selection of abrasives, cutting and buffing tools.
Technical Guru
The more expensive (and better fitting tools, i.e. Snap-on) really make a difference when you have to deal with a corroded fastener. And for certain sizes that you know are used a lot, you are better off just spending the extra money now. For anything more than a one-time use, even if only to save your sanity... At a minimum I would buy a 3/8ths drive 10mm, 13mm sockets plus 6mm and 8mm hex socket drivers from Snap-on or the equivalent. Their comfort grip flex head ratchets are really good too but expensive. The thing is the ratchet will be your most used tool!
Though it is true that you will need to buy more tools along the way, a good quality, basic tool kit is the best way to start off imho - i'd go metric and standard if you live in US. I have a Crescent brand tool kit I bought from Costco several years ago and takes care of maybe 75% of my needs around the cars and house and boat. It is compact and is the first thing I grab when I tackle a problem. I have a large rolling two section tool box with a lot of other tools that I have collected over 30 years as well. Craftsman is good, and this Crescent set has been fabulous.
