Experience with the new oil filters?
Does anyone have experience with the new Porsche MAHLE small filter? Purchased oil filters from the dealer for my bi-annual oil change and the small filter 993-107-203-03 (and 04) are superceded by 993-107-203-05. It is a previously verboten MAHLE filter but has the Porsche logo, is made in Austria, is the OC229 version and is now specified for the 993 turbo by Porsche. I've never had a smoking issue and certainly don't want one.
The big filter 993-207-201-02 is superceded by 993-207-201-03, also a MAHLE filter but with a Porsche logo, made in Austria and is the OC 213 version. Presume this is fine.
Thanks in advance for your advice.
I think I used them on one 993TT (as recommended by Sunset), and seems to be fine over the summer, but he also has the 996 Check Valves in place. I know, I did not like that it is in a Porsche box and then Mahle is on the filter, especially when we thought if you saw a Mahle small filter on a TT, it's wrong!
Who knows why they superseded the last one, might be technical, or maybe financial? Have not had a chance to take one apart (yet).
Cheers,
Mike
Cheers,
Mike
Probably like many of us, I purchased many OE filters at once a few years ago so that they were always on hand when required - still have 4 or 5 changes worth. From my experience though, whenever there is a 'superseding' part its always OK.
Originally Posted by Vince964T
2 years ago with the new filter. No issues
I believed I may have used the 05 filter last 2 oil changes with no issue. Although I change my oil due time as opposed to mileage because the car is driven infrequently these days.
I have had previous smoking problems due to use of old Mahle filters and overfill on another occasion.
Car has no mods (oil lines or check valves)
No issues in a decade.
Bringing this back. The new (05) filters dont appear to have the big rubber flow back seal. I have experienced by drivers side turbo filling up with oil. Confirmed by draining 10 oz of oil out of it. Its a newly refurbed turbo so I dont suspect the turbo itself. I have, supposedly, 996 check valves installed (prior owner) but it could be bad. Thoughts?
I've been buying them from Sunset - no issues to report. Regarding the check valve- I too noticed it was labeled Mahle but thought the view from the top looking down appeared to reveal the check valve
