993 Turbo Forum 1995-1998
993TT in higher speeds..
Old 09-05-2007, 05:43 PM
Jussi
Jussi's Avatar
Default 993TT in higher speeds..
I have tested my car in private roads and an airports at high speed...
Specs:
I have new Bilstein PSS9 which are 4 wheel balanced with Porsche specs.
They are 1cm lower at front and 7mm lower at rear than stock.
PSS9s has been set up 2 at front and 3 at rear (that stiffness).
Tires (Michelin PS2) are also in good condition.
My car uses stock aero parts.
But when I drive fast, like above 250km/h, the car feels unstable and dangerous to drive.. So for example 280 feels like suicide
Is it because the ruts in the road
or are these cars just so bad even they max. speed is 290 ???
or what else can be a reason?
Have anyone else noticed that thing?
Old 09-05-2007, 06:54 PM
Turbo993
Turbo993's Avatar
The 993tt is a car that was designed some 15 years ago - so you cannot compare it to a modern 911 or other brands.
You have to work behind the wheel and after 2-3 hours of high speed driving I am personally very exhausted, especially since the autobahn is much more demanding than a regular race track due to traffic etc.
Nevertheless I can take my 993tt to 320 km/h, it is a perfectly safe car as long as you are fully aware of the road.
Old 09-05-2007, 06:59 PM
TB993tt
TB993tt's Avatar
"feels like suicide" -first thing you have said which I 100% agree with
https://rennlist.com/forums/showpost...87&postcount=1
Old 09-05-2007, 07:17 PM
Rassel
Rassel's Avatar
Elaborate please..
Old 09-05-2007, 07:32 PM
Stummel
Stummel's Avatar
keep trying :-)
Mine felt very planted at its lousy V-Max speeds.
The 996GT2 front end felt light / not connected at 320kph.
Old 09-05-2007, 08:14 PM
IamSMC
IamSMC's Avatar
Why are you running stiffer at the front?
Also, did you check the alignment?
Old 09-06-2007, 09:35 AM
dbf73
Boost Junkie
dbf73's Avatar
also - do you have some (nose-down) rake in the car?
Old 09-06-2007, 09:58 AM
Jussi
Jussi's Avatar
Yes, I agree. The car is very "lively" when going Fast..
Old 09-06-2007, 09:59 AM
Jussi
Jussi's Avatar
Originally Posted by Rassel
Elaborate please..
I have to scan and show that adjustment paper..
Old 09-06-2007, 10:02 AM
Jussi
Jussi's Avatar
I searched about those PSS9 settings from here and make my own decision after what I had read. I also go race track one per month.
But I don't know are those good settings. They are first what I have been tested.. should I change them to what ?
I haven't check that alignment. The car came from some company and I trusted them. btw. How can I check that alignment myself?
Old 09-06-2007, 10:06 AM
Jussi
Jussi's Avatar
I don't know exactly what you mean..
But when I hit 280km/h, it felt like front was very light and lively and unstable.. and that's why I had to start braking.. but that road might be also in bad condition (the ruts in the road)..
maybe too little downforce at front? I have that Turbo S front spoiler but I haven't installed it yet, it might help for that?
Old 09-06-2007, 11:43 AM
Woodster
Woodster's Avatar
Mine was stabe to 155 or so and then "terrifying or amusing" at anything above.
I found it terrifying at that speed with a little Porpoising to boot!
MK
Old 09-06-2007, 01:49 PM
MOD500
MOD500's Avatar
Jussi,
Can confrim, yes, the 993 feels like a death ride at 180 mph plus. 195 laser speed (off the clock past 200 on speedo) feels frankly terrifying to me, bonkers!
Cheers
Martyn.
Old 09-06-2007, 04:47 PM
PierreTT
PierreTT's Avatar
Originally Posted by MOD500
Jussi,
Cheers
Martyn.
Old 09-06-2007, 05:10 PM
Jussi
Jussi's Avatar
Does anyone have better "high speed experience" with different front spoiler, like that Techart spoiler?
It was also in that "RS rocket science" car which went +350kmh easily (but it was narrow body)..
Or does that "turbo S" or RUF front spoiler make any difference?
Thanks for info!
btw.When I finished car's front end lightening, like LW battery, CF hood, no spare or tools, carpet off, etc..
I felt that at corner the car was worse to drive.. there was more understeer feeling and I had to cut speed(under 80kmh) at my well-known corner(90degree) way to my work..
so conclusion of that, there might be need for more downforce/agressive front spoiler?
Quick Reply: 993TT in higher speeds..
