classifieds |
membership |
rennlist |
photo album     sponsors | upload photo | chat | marketplace     |
| Register | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | My Recent Topics | Vendor Directory |
Thread Tools |
#1 |
Rennlist Member Join Date: Aug 2005
I am in the finishing stages of my GT2 conversion and I am trying to decide which tires and sizes to use.
My wheels are 9x18 in the front and 11x18 in the rear. The original sizes were 235/40 in the front and 285/35 in the rear. Can't get MPSC's (my first choice) for the rear in that size. The rear tires are only available in 285/30 or 295/30 with a diameter of 25.1 and 25.2 inch respectively. The front diameter is 25.7 for the 235's which I would like to stick with. What to do about the rear? Go to a 315/30 with a diameter of 25.5 which would work with the front or go to a different tire altogether (Hoosier etc.)? Any input greatly appreciated |
#2 |
User
i think some have gone to a 305 rear, can you get that in that brand?
#3 |
Rennlist Member Join Date: Mar 2004
It would seem that with the GT2 flares you would want to fill the flare with as much tire as possible depending on the wheel offset. I would go with the 315's on the rear and match the diameter with 235/245 in front.
How about some updated pictures of your car?
Scott 96' 993TT 3.8 |
#4 |
Rennlist Member Join Date: May 2004
Some here have gone 245/315
But wheel widths and offsets are critical for fitment Check with member AndyT
canysmc 1996 Porsche 993tt 2006 BMW M5 2006 BMW 750Li 2007 Mini Cooper S Vert Sparkling Silver/Malt Brown/Sidewalk Before: 1971 911 1985 911 1987 930 1985 535i 1987 535is 2001 M5 |
#5 |
Rennlist Member Join Date: Jul 2001
Jochen,
I ran 315's with no trouble on 11's. I wouldn't go more than a 263/35/18 in front with a 9'' if you have the right offset. I get a little tire rub on the inside with 245/40/18 Hoosier's on 9" rims if I turn the front wheels to right or left lock. With GT2 fender flares you should be ok. If you want to be safe you can run the 235/40/18. Diameter should't be a problem as the 315, 265 and 235 are all within 1/10 of an inch. Jimmy
Jimmy 993tt ANDIAL 3.8 twin plug (sold) 08' CLK 63 Black |
#6 |
Rennlist Member Join Date: Jan 2004
265/35/18 front on 9" rims. 315/30/18 rear on 11" rims. MPSC's. No GT2 fender flares.
Tim 2008 GT3 RS Signal Green 2008 Subaru WRX STI Super Production class Rally America 2005 F-350 SD 6.0 Liter Diesel DRW (vinyl matte black, 22.5's and a single stack) 1997 993 TT Arena Red/Black (sold and missed!) 1997 993 RSR 3.8 (sold and missed!) 2004 24ft Haulmark Edge (sold) |
#7 |
Lifetime Rennlist Member Join Date: Apr 2002
Hi Jochen, looking forward to see the final product impatiently!
As far as tires, you have many choices depending on your usage. I know this will be your fun street/track car, so I am guessing a set of R Compounds but also maybe a set of good street tires. The GT2 had the taller diameter (circa 26") with the 285/35s, it was a great choice as it gave enough tire contact area while keeping the width within reasonable limits to support decent gas mileage through taller gearing and less transmission wear through going taller rather than wider. As you know a taller tire will give you equivalent larger contact area similar to a wider one (say 295s). I am assuming you are running an LSD with your 2WD conversion, so in street tires, a good combo would be : Michelin PS2: Fr 245/40 --25.7" Rr 295/35 --26.1" You need to be careful with your fender flares, I know TB993TT had issues fitting the taller 295/35 tire in his car despite the flares, since they were fitted too tightly. Yoko Advan Sport: Same sizes as above. The 295/35 in N0 (Porsche) rating are heavy though relative to others. In R Compound tires for aggressive track driving and streetable overall with decent life; Sport Cup: Fr: 265/35 Rr: 315/30 For aggressive track without caring much about highway/street driving: Hoosier R6: Fr 275/35 Rr 335/30 The above gives excellent neutral handling for 2WD with a properly setup car, but is full track. My favourite is the MPSC setup above for street and track, like Tar6day as well. The Hoosier are fantastic in these sizes but too heavily biased towards track. The 265 up front still gave a decent (light)steering feel with the 2WD combo. The set of Michelin Cup slicks that I have are 27" tall so they are substantially taller than any of the above, some GT2 race cars used even 28" as you know, there is still a bit that we are leaving on the table. Cheers
Protomotive 993 3.8TT 2WD. 100-200kph -> 5.2s @1Bar |
#8 |
WOW!
Thanks to you all that is really great information and will make it much easier for me. Since I have 2 sets of Speedlines (Jean thanks again!) I think I will do two different set ups. One for the street with either PS2's or MPSC's and the other with Hoosiers. That way I have the best of both worlds! Thanks again to everybody for their informative input. I will see the car in a week or 2 and will post pics. It's coming along really nicely (albeit slow...) thanks to Dieter who is in my opinion one of the best out there! I had him install the Bilstein fully adjustable GT2 shock absorbers in combination with 900 lbs front and 1000 lbs springs rear Eibach springs. Swaybars are factory 23mm (5way) in the front and 20mm (3way) in the rear. I have a Matter half cage and I am still debating if I should weld a crossbar to it for the harness (it did not come with one!) or mount the harnesses on the rear shelf. Any input appreciated. Can't wait to drive the beast, it wil be my dream car coming true
#9 |
Car coming together! Enjoy the pics
#10 |
I'm Still Jenny
Rennlist Member Join Date: May 2006
Lookin' good! Are those the factory Speedlines or the Techart "copies?"
It really does look mean. I can't wait 'til it's done.
Charlie B. Last edited by WHB Porsche; 01-29-2008 at 10:14 PM. |
#11 | |
Rennlist Member |
Quote:
-- -Jeff '97 993tt 2WD '07 BMW M5 |
#12 |
they are the real Speedlines. I got one set from Jean and had another set built by Speedline.
Decided to go the MPSC route and now I am told no 315's available....
#13 |
Rennlist Member |
OMG!!!
I am in love...... Thats what my car wants to be when she grows up!!!! And Black too!!!! Ohhh my.... Simon.
Simon. "There is NO such thing as OVERTRAINING. If you're overtrained, it means that you didn't train hard enough to handle that level of training…... So you weren't overtrained; you were actually undertrained to begin with…... MORAL = The guy who trains the hardest, the most, wins." |
#14 | |
Guru
Lifetime Rennlist Member Rennlist Small Business Sponsor Join Date: Aug 2001
Quote:
Amen to that! What an awesome car! Always wanted to do a GT2 look (and go, for that matter) -- Cant wait to see more images!!
Is this a great place or what? Chris 97 993 twin http://www.swiftengineering.com/ Cool Video Latest FN News |
#15 |
Rennlist Member Join Date: Aug 2004
i ran 245 and 315s on 9s and 11.5s. You can run 265s up front but will encounter some fender liner rubbing. Looking Good buddy ! I wanted to se my old hood on there : )
2000 GT3 Cup Car, Becker VIP#1: (SOLD) 1997 993 TT (SOLD) Thanks to: http://www.reiser-technik.com/ http://www.ultimategarage.com/ http://vbdgraphics.com/ http://www.emersonautobody.com/] |
| Tags |
| 235, 2653518, 993, 993tt, 9x18, clk, porsche, size, sizes, stock, tire, tires, turbo, twin, wheels |
| Thread Tools | |
