classifieds |
membership |
rennlist |
photo album     sponsors | upload photo | chat | marketplace     |
| Register | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | My Recent Topics | Vendor Directory |
Thread Tools |
#31 |
Rennlist Member Join Date: May 2004
My car idles around 850 so that shouldn't be a problem if its tuned right. The wife would probably have my head if I added another track day this year unfortunately, lol. FYI I managed to get 275 and 335 hoosiers to fit yesterday (3.5 fr and 3.0r) camber and they absolutely rocked yesterday at mid ohio so you should be able to get them to fit as well. The left rear did tend to roll over a bit despite 36 hot pressure though. Getting some stiffer springs from Steve Weiner should hopefully help that.
Protomotive 993tt 600rwhp, 132mph 1/4mile Protomotive 996tt 880rwhp, 147mph 1/4mile |
#32 | |
Rennlist Member Join Date: Oct 2007
Quote:
![]() Now the big question, are they worth the extra $$ in performance over the 245's? My other question would be if your braking points were the same with new setup. You added a half deg of cambe which one would think would extend them but you also added more rubber up there You should tell your wife that she can go shopping in South Haven while you go play at the race track. That way you are both happy! We have a few guys doing that already for this event
1997 993tt: 2WD, Protomotive, Moton, ERP, Guard, etc Nogaro GT2 conversion ![]() Kelly Moss sponsored DE champion FS: Brand new rear lexan window. Sheilds brand all options pm if interested! |
#33 |
No question the 275's are better. Much less understeer. Didn't get hard on the brakes as the current ones are quite worn. Will test next month at Elkhart after 380mm ones from Steve Weiner are put on next week.
South Haven won't fly but I'll run proffer Saugatuck and see what happens.
#34 | |
Quote:
Hope you can make it to the event. Would love to pick your brain about a few things prior to driving my motor down to todd later this fall.
#35 |
Rennlist Member Join Date: Aug 2003
Does anyone know how 993 Cup Cams differ from the RS cams and so whether they would be a good alternative for our cars.
The part numbers appear to be: 993.105.246.70 (rhs) 993.105.247.70 (lhs Steve |
#36 | |
Rennlist Member Join Date: May 2001
Quote:
valve open 10.4 BTDC 51.7 BBDC lobe center 112.8 ATDC 107.5 BTDC valve close 66.6 ABDC 10.4 ATDC duration 256.9 CR 242.1 CR net valve lift 0.4905 inch 0.45176 inch here are the specs for the hyd 993RS cams valve open 6.9 BTDC 58.7 BBDC lobe center 113.8 ATDC 113.8 BTDC valve close 68.7 ABDC 6.7 ATDC duration 255.6 CR 245.4 CR net valve lift 0.4902 inch 0.4326 inch Andial used both on 993tt
Bill Verburg '76 Carrera 3.6RS(silber hotrod), 993RS brakes, SC/RS trans, Ruf aero, Bilstein sport, Kinesis 8 & 9.5 x17, 235/45 & 275/40, '95 993RS M002 optic, 3.8RS engine, RS brakes, M001 G50/30 Cup trans, RS M002 aero, RS 8 & 10 x18 Speedlines, GT2 oil cooler, RS sways, JIC comps My Home * My Pelican Home * Brake Info * Wheels |
#37 |
Thanks for that Bill
I don't suppose you also have specs for the stock turbo cams and the stock 993 cams in a similar format? best regards Steve |
#38 |
User
Does anyone have any info on the RS Tuning sport cams they offer for the 520ps kit http://www.cargraphic.co.uk/index.ph...,1052/&start=3 , how do they differ from the 993RS cams?
| Tags |
| 36, 944, 964, 993, 993rs, atdc, band, btdc, cam, cams, conversion, gt2, lifter, porsche, power, powerband, solid, specifications |
| Thread Tools | |
