Bewildered by 993 Turbo's brakes
Guys,
I am about to tackle -- once again -- the brakes on my 1997 993 Turbo. I did them last year because the inside of the brake rotors were severely rusted. At that time new rotors and pads were installed. That was something I did myself in my garage. I also had the brake fluid flushed and the system bled at the dealership. Now, merely one year later, the inside of the rotors are once again severely rusted. I tried driving the car and braking heavily, but that does not help. It seems to me as if the inside pads just do not contact rotors.
Any idea what could be wrong?
Here are some photos of the symptoms. Not nice, huh?
Thanks for letting me know what could cause this.
Regards,
Rik Gruwez
Bruges, Belgium
Regards,
Rik Gruwez
Bruges, Belgium
OK. Can I get a caliper rebuild kit from Porsche?
Rennlist Lifetime Member
Are the stainless steel plates inside the calipers that the edges of the pads rest on lifting and preventing the pads from moving properly? Corrosion develops underneath the plates and causes them to lift. Did you have any trouble installing the new pads into the calipers?
GRUWEZ:
PM Bill Verburg regarding your brakes, he knows alot about Porsche brakes.
Also, you want to contact this company to see if they have what you need:
http://www.vehiclecraft.com/index.html
Are the stainless steel plates inside the calipers that the edges of the pads rest on lifting and preventing the pads from moving properly? Corrosion develops underneath the palts and causes them to lift. Did you have any trouble installing the new pads into the calipers?
Regards,
Rik
Caliper pistons can exert so much pressure that it is unlikely that the pads wouldn't make contact due to this, much more likely would be a failure to release resulting in overly worn pads. Lack of pad contact is almost surely due to corroded pistons and bores because of old brake fluid and can only be fixed by caliper replacement.
I removed one caliper today to do some more investigation. The pistons and bores turn out to be OK. Check the pictures below. I do not see any corrosion or other damage that could lead to a binding piston.
However... it was impossible to pull out the pistons by hand. They are a very tight fit in the bore. As it turns out, the tight fit is caused by the bore seal. After I pulled out the bore seal, the pistons can be freely moved by hand in their bores. Now I must say it is quite cold in my garage/workshop, probably around freezing, which makes the rubber seal probably pretty hard.
So far I still have not discovered what could cause the inner pads not to touch the brake rotors. I spoke to Gert at Carnewal and he did not have a clue either.
Does anyone have an idea where to look further?
Thanks,
Rik
Thanks,
Rik
