classifieds |
membership |
rennlist |
photo album     sponsors | upload photo | chat | marketplace     |
| Register | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Dealer Listings | My Recent Topics | Vendor Directory |
Thread Tools |
#31 | |
Rennlist Member Join Date: Jun 2001
Quote:
Ziad '96 993 Twin Turbo - Black/Beige, UMW Stage 1, PSS10, H&R sway bars, RS engine mounts, LWF, Ruf oil cooler, Fikse Profil 10, Turbo S ducts |
#32 |
Rennlist Member Join Date: Feb 2002
John, that would be good. I should pop up and visit you to check your new face any how.
968 CS 964 Turbo 993 RSR BMW 320se |
#33 |
While we are on this subject.... I have never looked at a 993tt ECU, but i'm guessing the MAP is stuck on a EPROM and the "Locking down" is done through the ECU "software", so it may stop the original Motronic interface from letting you remap, but it shouldn't stop me as i'll write the code myself????
#34 |
Rennlist Member Rennlist Site Sponsor Join Date: Jun 2001
James, the European tuners are smarter than that.. They have encrypted chipset>secondary board>NON STOCK.. Unless you have the "key" you won't be able to access the memory.
www.Ultimatemotorwerks.com kevin@ultimatemotorwerks.com kmatwichuk@att.net 360.805-9066 |
#35 |
Rennlist Lifetime Member Join Date: Nov 2003
#36 |
#37 |
Its as if they were expecting people to hack their boards.....
#38 |
Just to mix up the discussion a little. I have enclosed a picture of a K26/24 cartridge and compressor housing machined/CNC'd into a K16 turbine housing. It is not a easy task.. Massive amounts of metal have been removed within the housing and all diameters have been increase. I have customers that do NOT want lag. One can read Ziad's post. They do not want to sacrifice the bottom end to shift any gains on the topend.
Yes, I have K24 turbine housings available for those that need and want the K24's. But as a business owner I have to adapt and offer components that customers want. We can look at the VNT 997TT housings, they are a tad larger than the K16's> but one can quickly machine a K16 turbine housing to exceed the internal volume. The K24 tubine wheel is a full frame size larger over the K16 turbine wheel. and it does dwarf the K16 turbine wheel in blade area and diameter. FYI, it is the turbine wheel that sets the frame size of the KKK nomenclature. When one machines the K24 turbine into the K16 turbine housing it does add another twist and options to customers.
#39 |
User
Kevin, could you take these and turn them into a pair of new style K24/26's?
![]() ![]() ![]() James, the op didn't make me look any better mate, just added more scars to my already ugly mug! Boxing in my teens didn't help! Girls like scars though so it's all good
#40 |
JBL, you have a set of 993 K16's with some funky bronze paint on the turbine housings. So you want to start out with K16 turbine housings vs K24's??
#41 |
User
Not if it isn't a good idea, i just thought from your post that you could do them with any housing. I will need a pair of turbos that will be optimised for the 520ps map. So i guess it will need to follow the RS-K24/26 design with whatever tweak you think will improve it?
If it's a good idea and it would save money to use my current turbos then that would make sense, if it's a compromise and i would be loosing something along the line, be it performance or cost then obviously not. |
#42 | |
Rennlist Member Join Date: Jan 2004
Quote:
Magnus |
#43 |
User
Love this vid of a 935 engine Micke built http://www.youtube.com/watch?v=wPfK_BispVo Would love to have this in the back of my 930
#44 | |||
Rennlist Member |
There are good news and bad news.
Good news is that when I least expected it I got an email from RUF basically answering all my questions . I had more or less given up that alternative as a result of numerous emails and phone calls leading nowhere. And waiting, lot's of it... . . . . I think they are just really really busy. RUF has to be my #1 choice for a mostly street car. It's a proven package. It even comes with a warranty. Expensive but great value to boot. And a very driveable alternative producing (from what I have heard) in excess of 500hp with minimal lag.The bad news is that the quote I got (which in itself is a ton of money) is without labour charges . I didn't realize this before. I have no idea what they charge for this but I would expect around 40hours of work maybe? (turbos, cams, oil cooler, cats etc.). I guess I'll just have to wait and see what they say next week. RUF will retain the stock rods with this package. I'll have to summarize/line up the different alternatives and their respective ballpark costs. Quote:
I think the 993RS 3.8 cams are like 1400usd new. Good to know because CG charges 1625eur for the cams in the 520ps kit. Quote:
Also, what kind of powerband can you except your special "RS-Tuning K24/26 ZC" to work in? 490-550hk depending on setup? I know from the link posted in my initial post that RS-Tuning uses the same K24RS turbos for their 490ish kit as for their 520ish kit. The only difference there being that the cams are replaced in the 520ps kit. But should one decide to up the boost a bit or do other upgrades (twin plug, con rods, I/C, tweaked DME), AFAIK your RS K24/26 ZC turbos are capable of making more power than 520hp? I mean the turbos wouldn't be the limiting factor in that case. Sorry if it's unclear but I'm fairly new to this, still learning ![]() Quote:
Btw I got a PM from Rickard. Thanks for keeping me in the loop .
Viggo '97 993TT - "The Black Pearl" - Past Porsches: '98 993TT Arena red - Museum Piece - "Last of the air cooled" - Gone '97 993 C2S Vesuvius - All stock - 25.000 mile GQ - Gone '97 993 C2S Vesuvius - All stock - 100.000 mile Beater - Gone to France |
#45 |
User
Toby, do you know whether Martyn's car uses stock orange injectors, and is it single or twin plug?
More importantly, how certain are you that Vic's GT2 was running the RS 520 kit? Wayne said it only posted 470-480bhp when it came to him, maybe Vic had changed the turbos or cams and something was out of kilter? I know you said he had gone twin plug, but that wouldn't loose power would it |
| Tags |
| 911, 993, buy, cams, camshafts, cargraphic, cargraphics, ecu, kkk24, muffler, porsche, specification, tt, tuning, turbo, twin |
| Thread Tools | |
