classifieds |
membership |
rennlist |
photo album     sponsors | upload photo | chat | marketplace     |
| Register | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Dealer Listings | My Recent Topics | Vendor Directory |
Thread Tools |
#46 | |
Rennlist Member Join Date: Mar 2004
Quote:
Scott 96' 993TT 3.8 |
#47 | |
Rennlist Member Join Date: May 2001
Quote:
They probably changed out other stuff during the twin plugging. Lots of things can lose you power including not having it in the first place via didgy dynos - as we know
997GT2 '09 RS Tuning -engine dyno tuned 993tt RS Tuning 2006 street 3.8 MAF spec Rennlist User#386 |
#48 |
User
No wonder it was down on power if it went to Colin first, he probably ported the heads or something
![]() Do you know whether Martyn's engine uses the stock injectors? What injectors does your 993 use? |
#49 |
Rennlist Lifetime Member Join Date: Nov 2003
#50 | |
Quote:
RS seem to prefer using stock stuff and only change when the engine dyno says limits are r/breached and other alternatives work etc. No idea of the limits of stock injectors altho I imagine there is the usual amount of BS around about how big you need to go for X amount of hp..... Edit: AFAIK my 580HP 3.8 used stock ones also
#51 | |
Lifetime Rennlist Member Join Date: Apr 2002
Quote:
For stock 44lbs injectors, the maximum FWHP achievable with stock FPR is 500-520FWHP.. With a 5 Bar FPR, the maximum you can reach with stock injectors is around 580-600FWHP.. These numbers in both cases are stretched and you need to ensure you have excellent engine dyno/chassis tuning performed or else you risk going lean.
Protomotive 993 3.8TT 2WD. 100-200kph -> 5.2s @1Bar |
#52 |
Rennlist Member Rennlist Site Sponsor Join Date: Jun 2001
Viggo, K24 turbine housings and K24 turbine wheels are used with the RS/Cargraphic based design>they have to be used. Guys the RS tuning>mapping does not account for the load or early boost request if you insert K16 based turbine housings.
The Ruf 490 kit is K16 based. There are ZERO K24 components in the turbochargers on the turbine "hot" side. It would be "very" helpful if Toby can post the early published data between the RUF 490 and the RS Tuning 520 kit. For the record, the RUF 996TT 590 turbochargers are more similar to the "build sheet" of the RS Tuning 520 kit than the Ruf 490 kit ![]() Stepping forward 12 years the hardware tweaks that I have done on the K24's allow us to have boost alot earlier than previously had. While I would like to say that it is possible to get .5bar of boost at 2200 RPM's with the K24 turbine section with the NEW 997GT2 compressor stage>that would be a stretch. BUT we will see .5bars around 2900 to 3000RPM's ramping up very quickly..
www.Ultimatemotorwerks.com kevin@ultimatemotorwerks.com kmatwichuk@att.net 360.805-9066 |
#53 | |
I'm Still Jenny
Rennlist Member Join Date: May 2006
Quote:
How are they actuated? Via oil pressure? I imagine it wouldn't be too hard to fab up a control system for them.
Charlie B. |
#54 |
There are a few hurdles that need to be addressed. On the 997TT and 997GT2 the ECU will pull timing and slow the turbine wheel when the exhaust gas temps reach 970 to 980 degrees C. This VNT turbocharger is running higher backpressure level vs "any" turbocharger that we have fitted to the 930 thru 996TT.
What is the implications on the combustion temperatures on the air-cooled engine>cylinder head temps. How much boost can you run with what level of backpressure before we see detonation. The 5.2 Motronic cannot read the EGT's nor does it have the built in electronic to control the electro-mechanical servo that operates/sweeps the turbine vanes. Yes, you could design and build a controller that would monitor RPM, boost, EGT, and backpressure. This unit would then be programmed to control the vanes. $$$$$ The cost for a new set of 997GT2 turbochargers is around $9500 pair..
#55 | |
I'm Still Jenny
Quote:
But back to Viggo's upgrades - sorry to steal your thread!
Charlie B. |
#56 |
Rennlist Member Join Date: Feb 2002
For those of us running Motec, that would be very easy. Kevin, why the increased back pressure on the VNTs?
968 CS 964 Turbo 993 RSR BMW 320se |
#57 |
James> Boost control on the VNT is a function of moving the vanes to SLOW down the turbine wheel. Similar to a jet engine when you land, you feel the thrust reversers. Backpressure is increased.
With our K16's or K24's when the ECU directs the turbochargers to lower the boost, a gate will open and divert the engine exhaust away from the turbine wheel. The result is LESS restriction "backpressure" on the engine.
#58 | |
I'm Still Jenny
Quote:
Charlie B. |
#59 |
Why not just run external wastegates and control boost that way. You still obviously keep the other benefits of the VNT?
#60 | ||
Rennlist Member |
Quote:
If it's possible, do you think that you could use the existing RS-Tuning software that comes with the kit and that the tweaked turbos will just improve on overall performance with higher low range boost pressures etc.? Or is custom mapping preferable? Also I have 100cell cats on my car, is there any way of checking if they are up for the task? I suspect they are Gemballas but not 100% sure. I'll try to get the car on a lift and snap some pics. If the 100cell cartridges are 130mm in diameter, I should be all set? I think I have the standard cats with the cartridges replaced with 100cell ones. Still waiting to hear back from RUF. But I did some calculations and the difference in price in the end is huge with the TurboR kit vs. RS-Tuning 520 with UMW tweaked turbos. Will keep you posted as soon as I hear from them. Quote:
Viggo '97 993TT - "The Black Pearl" - Past Porsches: '98 993TT Arena red - Museum Piece - "Last of the air cooled" - Gone '97 993 C2S Vesuvius - All stock - 25.000 mile GQ - Gone '97 993 C2S Vesuvius - All stock - 100.000 mile Beater - Gone to France |
| Tags |
| 911, 993, buy, cams, camshafts, cargraphic, cargraphics, ecu, kkk24, muffler, porsche, specification, tt, tuning, turbo, twin |
| Thread Tools | |
