Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat | marketplace
Go Back   Rennlist Discussion Forums > Turbo Technical Discussion Areas > 993 Turbo Forum
Old 11-06-2009, 11:10 PM   #1
cgfen
cgfen's Avatar
Default 315 - 30 rear and 245 - 40 front
yes
i know this has been discussed a few times, but now MY car's sheetmetal is at stake
and the board is a little slow right now.
http://forums.rennlist.com/rennforum...15-18s-ok.html
http://forums.rennlist.com/rennforum...-on-933tt.html
http://forums.rennlist.com/rennforum...for-993tt.html
i recently scored, (thanks Chris Walrod), a set of 996 TT wheels shod with NT01s;
315 - 30 X 18 rear
245 - 40 X 18 front
i've done a test fit and a mellow drive with no contact, but man, the minimal clearance between the tire and the inner lip of the sheetmetal is close close close.
no issues if i drive over a smooth road, but a "big" bump and some steering angle cranked in looks spooky.
my car has -2 degrees camber front and rear.
wheels are 996 TT
ride height = RS +10mm
96 C4S
Car is currently RWD only after AWDectomey, so diameters are not critical
anyone running something very similar with good success?
good success = no rubber to metal contact.
Craig
hmmmmmmmm none of the links seem to be working right now?????????
i'll try to sort it out
1996 C4S Iris Blue over grey........ still trying to figure out what to do.
2006 Subaru wagon.............my other flat 6 boxer powered car.
2009 C2S, my sweetie's car
cgfen is offline   Reply With Quote
Old 11-07-2009, 12:15 AM   #2
911/Q45
911/Q45's Avatar
I've run those wheels with 235/40 and 315/30 for a long time with no problems. Much track use and no rubbing from any of several brands of tires. The camber goes more negative as the suspension compresses, so bumps shouldn't be a problem.
1996 TT, sport seats, delete sunroof
911/Q45 is offline   Reply With Quote
Old 11-07-2009, 12:35 AM   #3
Tour18
I'm about to put a 315s on mine. I have made a zillion measurements. The 315s just aren't that much bigger...
'96 993TT, '02 Z06, '03 986S
Tour18 is online now   Reply With Quote
Old 11-07-2009, 12:50 AM   #4
Greg H.
Greg H.'s Avatar
I run those tires and rims with -1.9 negative at about Row030 ride height with no problems at all.
Greg H.
Greg H. is offline   Reply With Quote
Old 11-07-2009, 02:00 AM   #5
cgfen
cgfen's Avatar
Quote:
Quote:
bigger than what?
I've run as large as 295 - 35 with no issues.
295s are ~ 0.5" taller and 0.75" more narrow than the 315's.
Quote:
Greg H.
thanks for taking the time to comment guys, i'll let you know how it goes.
Craig
Old 11-07-2009, 03:27 PM   #6
JJayB
JJayB's Avatar
I've run 315 with no problem. You may get inside wheel rub with the 245x40's on full steering lock.
Jimmy the fugitive (rehabilitated by traffic school)
993tt ANDIAL 3.8 twin plug
08' CLK 63 Black
JJayB is offline   Reply With Quote
Old 11-07-2009, 04:58 PM   #7
Tuner1
Tuner1's Avatar
On the rear fitting the 315/30-18 is easy.
For me the big issue is tire vs wheel width. I would not run larger than a 305mm tire on an 11" wheel (Porsche uses 305/12" for 997 and 315/12" for 996).
Same goes for the front. I would not run wider than a 235/40-18 on an 18x8" wheel. Using a 245/40-18 on an 8" wheel really compromises the profile of the tire...IMHO, YMMV
FYI, this advice is also based off the wisdom passed onto me by a wise racer/engineer at Michelin
Tuner1 is offline   Reply With Quote
Old 11-07-2009, 10:18 PM   #8
pstoppani
pstoppani's Avatar
I have 315s on 11" wheels and they work great, and 11" wheels are well within the spec for those tires.
Pete | 97 Turbo | 06 Boxster S | 06 M3 | 05 Elise
pstoppani is offline   Reply With Quote
Old 11-08-2009, 12:21 AM   #9
Tuner1
Tuner1's Avatar
Quote:
"Within spec" for sure but not ideal for maximium performance applications.
Of all the tire engineers I have asked (yes I actually go out of my way to track these guys down) every single one of them has strongly suggested wide wheel/narrow tire is superior to narrow wheel/wide tire...within their given specs range.
Like I said, YMMV. On a stockish 993 with softish suspension it likely won't matter what you run
Old 11-08-2009, 12:35 AM   #10
Al Pettee
Al Pettee's Avatar
Agree 100%.
Just because the tires fit on those rims doesn't mean they'll perform any better-indeed, with the extra tire sidewall from tire bulge, one is likely to experience "wobble" especially in turns. If you want bigger and wider tires, then get bigger and wider rims first.
This thread is kind of like those bench racing arguments:
"Oh yeah, well my Corvette has 3000hp so it has to be faster than your Corvette that has only 2000hp."
1997 993TT-Protosport 3.8L, twin plug, GT3076R's, 700+HP-black/black-cashmere.
2005 996TSCab-EVOMSit GT700, Hitachi MAF, Sachs level 3 clutch, Milltek 996TT/GT2 exhaust-triple black.
2006 Noble M400-Technical Dimensions "M600," 573RWHP-blue.
2007 Audi RS4-MTM supercharger/exhaust/clutch/LWFW 530HP-red-"The Cherry Bomb."
Al Pettee is offline   Reply With Quote
Old 11-08-2009, 01:15 AM   #11
pstoppani
pstoppani's Avatar
I didn't get the impression the OP was looking to set any world records where that last millisecond of performance was a requirement...
Old 11-08-2009, 03:19 AM   #12
Tuner1
Tuner1's Avatar
All the more reason to stick with OEM size tires
The 993 GT2 used 18x9" with 235/40 and 18x11" with 285/35!
Taken from the first link posted by the OP:
Quote:
Jean: A 245 on an 8" wheel is not recommended if you choose to go this route..
Quote:
jrgordonsenior: I ended up with 265/315 MPSC's on 9-1/2 & 11-1/2 rims after testing many different combinations.
Regardless, I am far more OCD when it comes to rubber than most people could ever imagine. Unless my advice is requested I will bow out of this thread
Old 11-08-2009, 04:18 AM   #13
Greg H.
Greg H.'s Avatar
If I only have an 8" front rim, are you saying my car will understeer less with a 225 than a 245?
Greg H.
Old 11-08-2009, 12:01 PM   #14
canysmc
canysmc's Avatar
Greg H.
with a 295, 305 or 315 rear?
canysmc
1996 Porsche 993tt
2006 BMW M5
2006 BMW 750Li
2007 Mini Cooper S Vert Sparkling Silver/Malt Brown/Sidewalk
Before:
1971 911
1985 911
1987 930
1985 535i
1987 535is
2001 M5
canysmc is offline   Reply With Quote
Old 11-08-2009, 12:16 PM   #15
Spartan
Spartan's Avatar
Should fit just fine, used to run that combo when I had tiny fenders
I highly suggest 275f and 335r but some slight modifications might be in order
1997 993tt: 2WD, Protomotive, Moton, ERP, Guard, etc
Nogaro GT2 conversion
Kelly Moss sponsored DE champion
FS: Brand new rear lexan window. Sheilds brand all options pm if interested!
Spartan is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 1998 - 2007, Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
