Question about HP
I think it is possible, but you'd have to use bigger turbos. They can generate the power you want, but it will be up at the top end, and you'll have less mid-range torque. You'll also need an aggressive ECU tune and sport cats. Don't forget an additional oil cooler for longevity. The Ruf Turbo R generates that power with only slightly larger turbos, but they also use sport cams. Does changing camshafts count as "going into the engine"?
^^^^ As I smile I see, getting the power "out" literally. Oh boy. This forum is so much more humorous than over in the 996tt and 997tt forums. I guess it comes with the type of personalities that own these cars. I dig.
I am always apprehensive when these motors are jacked to 475+ HP without any internal work being done, but I have not seen any longevity numbers for the bottom end/bearings/con rods/wrist bearings/pistons/head seals, so maybe its' just the engineer in me. We have seen a few high mileage examples that are stock and may have needed just valve guides, but how many examples of really boosted cars with higher miles?
Cheers,
Mike
Cheers,
Mike
I am always apprehensive when these motors are jacked to 475+ HP without any internal work being done, but I have not seen any longevity numbers for the bottom end/bearings/con rods/wrist bearings/pistons/head seals, so maybe its' just the engineer in me. We have wasseen a few high mileage examples that are stock and may have needed just valve guides, but how many examples of really boosted cars with higher miles?
Cheers,
Mike
Cheers,
Mike
Rennlist Lifetime Member
^+1
There's been a couple/few of the high hp builds on rennlist that see track time requiring multiple engine rebuilds/tear downs for head sealing etc. I think usage makes a big difference. I keep my foot floored trying to keep up with well driven newer cars a good 1/4 of the time on the track, occ hitting the rev limit for 30 mins to an hour track session - totally different from brisk street driving.
Yes, but this is the type of driving that makes it worth the build ... and the rebuild.
+1. Very important. it's the first thing I did when I bought my car. I used the Cargraphic cooler. Car never gets hot,
