Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat
Go Back   Rennlist Discussion Forums > Turbo Technical Discussion Areas > 993 Turbo Forum
Sign in using an external account
Register Forgot Password?
Search
Thread Tools Search this Thread
Old 10-14-2013, 02:21 PM   #1
Constantine
Small Business Partner
Constantine's Avatar
Default New driveline product for the 993C4/TT!
We just finished our work on fixing a common problem in all 993 C4 and TTs where the torque tube drive shaft fractures and causes a loss of the four wheel drive feature.
Our research found the original drive shaft is constructed of a hollow tube where the splined end shaft which engages into the transmission is simply welded together. Time and aggressive driving can fracture the weld.
We designed a replacement shaft which is longer and is mechanically captured within the original hollow drive shaft. This was harder to design and execute than simply welding it back together, but we felt welding was not the proper choice for several reasons.
Below is a shot of our new splined end installed into the original 993 torque tube drive shaft. The splined end is made of a heat treated/cold finished material which is stronger than the stock piece (shown below the new one) it replaces. The splined end fits the 993 end coupler perfectly as the original.
With this new product we can now service any 993 C4 or 993 TT owner when it comes time to refresh their torque tube and who wants to retain the originality of their Porsches four wheel drive system.
This newly fixed drive shaft will be tested in a volunteers 993 C4 if he is still on board. If not, we might be needing a volunteer from this group.
To remove this ad, register today or login if you already are registered!
Constantine
constantine@blackseard.com
http://www.blackseard.com
Rebuild parts for 924, 928, 944, 959, 964, 968 and 993 Torque tubes
Constantine is offline   Reply With Quote
Paid Advertisement
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
Copyright ę 1998 - 2007 Rennlist.com
Advertise on Rennlist - Privacy Statement - Terms of Service - Jobs
Emails & Contact Details
