Dyno might have ruined my visc. coupl.
I did a Dyno test on a "AWD" Dyno set up at Thunderhill here in C.A. Two roller table and I had done it a couple of years ago. The difference this time was that they removed the belt that coupled the two rollers together. First pull had both wheels spinning. That was the last time they spun.
I think I know the answer to the question, but I'll ask anyway. Would the difference in speed between the two rollers (not coupled) be enough to wreck the viscous coupler? I limped the car home below 70 mph and was smelling gear oil by the end of the 3 hours. Sounded different too. No rattling, just friction noise.
If it's an obvious yes, where does that leave me in regards to compensation from the shop who (in my mind) should have known that they can't do my car on that equipment. Your honest opinions would be greatly appreciated. I know that these guys up there aren't making a lot of money but I can't afford to make this repair either.
Thanks for your advice.
Dealer retail replacement of vc is 3k easy. Indy will be significantly less but part still comes from the fatherland only.
any documentation stating the front wheels were spinning on first run? If not it's your word against theirs. But the threat of litigation should get them to agree to half an indy repair. just a thought. Also they should have insurance for this sort of thing (if their was no waiver)
I'm sorry but an all wheel dyno (unless coupled mechanically) is a no no on these cars, well documented on these boards with multiple threads on the topic.
Should have checked here first prior to doing your
Dyno session. These cars are not that common, you have to do your homework.
Qwen, sorry about your V coupl
Have you thought about going rear wheel drive? Did you ever get that lean problem resolved? I was going out to Thunderhill around June 6th 7th Ill keep a heads up before I dyne there again. I have done it twice there with no problems. We finally have a fellow here in Reno that has a 4WD dyne. I have posted this video before but I will put it out again.
Thanks for the thoughts.
As stated in the post. I had done it there successfully 2 years ago when they had the coupling belt. I had no idea they had taken the belt off.
AirRick, yes I did resolve all of my issues, car was running super strong. This was the first venture out in a long time of niggling little issues. Now a bigger issue to deal with. Good to hear from you.
I have thought of 2 wheel drive but eventually this car will be for sale and I know that it will sell better in awd.
Do NOT have your AWD car dyno'd there. Not that I needed to say it at this point, but...
Take the front wheel drive off. It's ruining these cars. I have a 993 TT that I race. Why dyno these anyway? They are too powerful for street driving as they are.
Cheers,
Mike
Have you thought about going rear wheel drive? Did you ever get that lean problem resolved? I was going out to Thunderhill around June 6th 7th Ill keep a heads up before I dyne there again. I have done it twice there with no problems. We finally have a fellow here in Reno that has a 4WD dyne. I have posted this video before but I will put it out again.http://www.youtube.com/watch?v=gu9FSuSdupA&feature=plcp
