993 Turbo Forum 1995-1998
Rear suspension
Old 01-22-2017, 05:21 PM
Hasse993
Hasse993's Avatar
Default Rear suspension
Winter time means 993 TT project time.
I am in the process of replacing the rear bushings with new ones from Elephant Racing. I need to remove the right wishbone arm but can't get it loose. It's stuck in the wheel hub. The left one is off. Any good tips?
Old 01-23-2017, 09:53 AM
993Godspeed
993Godspeed's Avatar
I have found that hitting it or tapping the head a few times with a hammer and adding liquid wrench penetrating oil has helped. (Blaster) Spray it and tap it and let it sit for a while. Do this at least 2x. Hope it helps.
One more thing is you could heat it with a blow torch and cool it with water, then heat it again. This eats away the corrosion.
Old 01-23-2017, 12:38 PM
OverBoosted28
OverBoosted28's Avatar
Please don't heat and cool your aluminum suspension components with a blow torch and water! Not very nice to the properties of the alloy. Get a big flat head screw driver, and use leverage to force it out. Smooth, slow "suggestion" to remove it w/o damage/injury.
Old 01-23-2017, 04:58 PM
Hasse993
Hasse993's Avatar
Default Unsuccessful
Thanks for the tips but it's still stuck.
I have soaked it with oil. I'll give it another try tomorrow
Old 01-23-2017, 05:32 PM
OverBoosted28
Are you trying to seperate at red arrow, or the inboard (yellow arrows)? If the red arrow, can you use a sacrificial pair of nuts, to pound and possibly crack it loose? Have a helper try and get a ball joint separator in, and give some slight tension (w/o tearing boot/damaging joint), as you strike on nut. Once that initial crack is done, it's good to go. Inboard, (yellow) should be easy to pry out. Get the nuts set up, use a long punch to reach from top camber link, trying to get a good hit on it, vertically. Hope this makes sense, and/or helps.Name:  IMG_9838.JPG
Old 01-24-2017, 09:20 AM
Quadcammer
Quadcammer's Avatar
Received 1,373 Likes on 794 Posts
I've had BMW balljoints that were stuck solid. Banging on the hub with a sledge did nothing. A ball joint separator was required to break these loose and when it came apart it was like a shotgun going off. May need one in this case if you have the necessary real estate to get it in there.
Old 01-24-2017, 04:50 PM
Greg H.
Greg H.'s Avatar
I used a ball joint separator and tore the rubber boot. Be careful.
Greg H.
Old 01-25-2017, 02:17 AM
Hasse993
Hasse993's Avatar
Default Still stuck
Greg H.
Thanks for all the input guys. I have tried all proposals. Need to be careful with the rubber boot.
One idea is to put a plastic bag with crushed ice on the hub and the bolt and leave it there for at least an hour.
Old 01-25-2017, 11:13 AM
Greg H.
Greg H.'s Avatar
Btw - I did the elephant bushings. You're gonna need a press. Are you going to replace the kinematic bushing? I did that one too but am not sure that was an upgrade. You will essentially be removing what Porsche designed into the suspension.
Greg H.
Old 01-25-2017, 05:35 PM
Hasse993
Hasse993's Avatar
Default Press
Hi Greg,
Yes, I'm replacing all bushes with new ones (sport) from ER.
I have a garage close to where I work an they have a press
Old 01-26-2017, 05:53 PM
Hasse993
Hasse993's Avatar
Default Torn rubber boot
Greg,
Were you able to repair the boot or did you buy a new wishbone arm?
Old 01-26-2017, 05:56 PM
Greg H.
Greg H.'s Avatar
Silicone. Working so far.
Greg H.
Old 02-03-2017, 05:53 PM
Hasse993
Hasse993's Avatar
Smile Problem solved
I borrowed a fork from the local garage. Hammered it in the ball joint and then hammered the nut from above and finally the wishbone arm loosened. What a victory
Now I have removed all the old bushes and the arms are up for a thorough cleaning.
Will get the new bushings pressed in next week.
Old 02-06-2017, 08:37 AM
DRPM
DRPM's Avatar
pls send pics
Old 02-11-2017, 05:25 PM
Hasse993
Hasse993's Avatar
Default New ER bushings
Originally Posted by DRPM
pls send pics
All the arms off the car and a pic of the fork which is my hero.
Quick Reply: Rear suspension
