996 Forum 1999-2005
PCM Phone
Old 09-06-2017, 05:54 PM
clwickers
clwickers's Avatar
Default PCM Phone
I have the following PCM in my 996. It has the phone handset as well.
Putting an O2 Sim in it or BT Sim it rings if I call it - it dials out and rings whichever number I programme in.
The only issue is when dialling out I cannot hear anything - no ringing tone, although I can hear the volume is turned up.
The same if someone calls it - the 'phone rings you can answer, and then hear nothing, other than the fact the volume is up.
I know it will only work with certain sims (900MHZ) however the fact that it makes receives calls seems to suggest sim is working.
Any suggestions please?
Chris
Old 09-07-2017, 01:00 AM
Mark I
Mark I's Avatar
Some head units only transmit BT sound from phones through the front speakers. You might check the fader setting & see if that changes anything.
Old 09-07-2017, 03:38 AM
clwickers
clwickers's Avatar
Many thanks - makes no difference - there is just a bit of 'white noise' with the volume full up.
It is like everything works as it should apart from the sound - i.e. it dials and receives you juust cannot hear a ringing tone when dialling out or anything coming in.
What I am trying to work out is if there is a problem with the SIM not being compatible, although if this was the case I would expect it not to work at all, or whether there are some setting or whether there is any 'updating (if possible)' I need to do.
It would just be nice to be able to make the call from the car.
Chris
Old 09-07-2017, 05:31 AM
Millemiglia
Millemiglia's Avatar
If you live close to a Porsche Center maybe they can retrieve some error codes from the PCM with their diagnosis tool?
Quick Reply: PCM Phone
