1999 996
The lower left hand lever will toggle through the OBC parameters/functions by pushing up or pulling down. Pull toward you to clear variable parameters (mpg for instance)
Some 99-00's don't have it available, the OBC needs to be activated with a Porsche scan tool, then if you don't have the additional stalk (assuming not), you can either buy the stalk and wire it to the gauge cluster, or you can use two of your blank buttons next to the climate control and wire those directly to the gauge cluster and cycle that way. Still needs to be activated regardless. If you have it activated without, it will show outside temperature, so you'll need buttons or a stalk to scroll through the OBC options.
I chose using two of the blank buttons because 1, it was easier, and 2, I like the addition of usable buttons next to the climate control.
Hmm... so mine shows the temp but has no stalk. Maybe I need to play with the blank buttons and see if they do anything.
Newb question, but is there a tech post on how to wire it in if it's not been done?
1500 miles I've driven and haven't even figured out how to program the radio!
There are writeups, and it's fairly simple. Two wires to each button, then depending on model you have to plug male connects into the back of the cluster in specific slots to function properly.
https://rennlist.com/forums/996-foru...m-buttons.html
I accidentally discovered that if you disconnect the battery, then reconnect, the displayed information reverts back to outside temperature, instead of countdown to empty. Mine does not have the OBC stalk either.
My 2cents
I have a "theory" as to why some 996s have an OBC lever (left hand side) and some do not.
My 996 Mk I's COA shows "On Board Computer" was ordered as an option, and it has the "OBC Lever".
So my theory is All 996s have the OBC, but only those that were ordered with that option have the OBC lever. Just a thought.....Porsche ALWAYS charges for options, sometimes a lot!
relinuca
relinuca
relinuca
relinuca
Early 996's had the OBC as an option. If the option was not purchased, the OBC is still there, just disabled. It can be enabled by a PIWIS or Durametric. The control for it can be added by buying the fourth stalk, or hacking a button to toggle the options. (see links above).
Later 996's had the OBC as a standard feature.
