Cylinder Scoring Repair cost?
amargari (02-03-2023)
From Australia I did the LN 3.4 to 3.8 electively and the LN deluxe kit. The rest is stock The engine purrs, with a mild growl via the top gear mild exhaust.
Brandon G Clarke offers the UK Hartech solutions. These are Rolls Royce level engineering and I suspect prices from Oklahoma.
I'm very satisfied with going up in displacement with LN's long track record and great supply. .
Facebook Post
I apologize in advance if this question was answered in the past.
when going with a larger displacement does it require any modifications to the heads?
I assume at least different head gasket, but is that only it?
Platinum Sponsor
The larger bore size really makes these 4 valve heads very happy. While head work is not required for a happy engine, proper head work can give huge gains without any losses of manners. What makes these engines next level is nailing the combination of displacement increase, head work, compression ratio, and cam timing alterations. Just going to a bore size increase will work fine, but you'll leave quite a bit on the table and never know it.
LN/BRS/FSI Customer Support
https://lnengineering.com/
https://flat6innovations.com/
meirschwartz (02-03-2023)
Thanks Yelcab and great info from Charles, I have a highly regarded local Porsche shop I'm planning to have do the things beyond my capabilities. One one the reasons I decided to rebuild the engine on my '88 was that a HUGE amount of the work is very doable IF you are reasonably competent, comfortable with a wretch and truly enjoy the process/work. On the other hand, some things take highly specialized equipment or skills. The trick is knowing the difference. I need projects like this...my wife only lets me in the house so many hours a week.
GC996 (02-03-2023)
Platinum Sponsor
Cam timing, I assume you mean changing the computer program for a different cam timing activation and duration? Because static cam timing at assembly is not changed if you use the factory method. I remember one of the selling points of LNE larger bore is that it "does not require software changes." Nothing ever was said at time of sale that "you would be leaving quite a bit on the table..."
I was not referring to cam timing changes in regard to software manipulation.
I was referring to mechanical camshaft timing alterations. FSI engines (as an example) do not utilize factory camshaft timing procedures in most cases. This is one way that much different results are created between FSI engines, and what may be a confusingly similar engine of the same displacement built by another builder. Factory camshaft timing tools are not generally used with cam timing procedures with FSI engines except to baseline the procedures from a TDC overlap setting.
Another question often asked is if you need to do custom tuning to the ECU - as long as all your sensors are in good shape (MAF, primary o2) the ECU will adapt.
