Repair or sell recently purchased 996 with bore scoring?
#32
Take a look at the engine guide here, these guys are the go to for engine rebuilds in the UK where I originated from. It’s a 74 page document but very detailed!
https://www.hartech.org/
#33
As far as cost go's , the "rebuild" would depend on the damage/mileage/desired outcome, so even with more labor cost, it could be less than a short block or much much more than a short block.
#34
I've read about many theories on what is the main contributing cause for the phenomena called "Cylinder Bore Scoring". Some argue it can been caused by the pistons expanding faster than the block during warm up in colder climates and with extreme factory tolerances, the pistons begin to rub against the cylinder walls. Others argue it's from "fuel washing" from ethanol gasoline which have poor lubricity chemistry. And, even metal contaminated oils... on and on it goes. Raby uploaded a video showing scored cylinders on a 2002 C4S. He demonstrates how deteriorating iron based piston skirts severely etch into the cylinder walls. Over time, it develops a clear case of scored cylinders. Just search "996 Bore Scoring" in YouTube.
#36
I kind of agree here. You can buy another cheap 996 for the same cost of a rebuild...These cars at these prices are disposable...Part out the old one and get some money back!
#37
That's why I made the Porsche YouTube videos. Hoping to help educate people on the possible issues when it comes to these cars.
If the car is still running, I would just drive it. Not worth trying to fix one issue when so many others are possible.
911fst (01-29-2020)
