What the heck is this???
Hey guys, I am in the process of replacing my AOS and I accidentally broke this small air line. When I was taking out the alternator, it sat right above it, if that helps (see below pics). I am having trouble locating it in the schematics, as I am not sure what it goes too. If you could steer me in the right direction I would greatly appreciate it. Not sure if this matters, but its a 2000 996 S2. I am not putting anything back together yet, as I want to narrow down what this goes to while I have everything apart, in hopes of easy access and replacement. You guys have been helpful so far, so hoping for more of the same! Thanks, much appreciated.
Scott
Scott
So that's the vacuum line that activates the RPM dependent butterfly valve in the (rear) intake plenum. Your broken piece is approx center in this photo, and you can see the vacuum line leading to the removed plenum piece bottom right.
You are a braver man than I. Replacing the AOS. You will probably brake more of the vacuum lines behind the alternator as they are really brittle. I would replace all of the Vac lines when you are in there.
All, thanks for the quick replies! I will heed your advice and replace them all while I'm here. The others don't seem brittle, but makes sense. AOS was a lesson in patience to get to it, but it's out and replaced. Now to put it all back together.
Good choice! I replaced pretty much every coolant pipe, clamp, expansion bottle, thermostat etc when I did the AOS. It seemed like such a good opportunity to headoff any age related failures whilst the shear pain in the **** of removing all that stuff was fresh in my mind.
Good job. Don't sweat the breaking that little line. I know it's frustrating, especially when replacing a part like the AOS is so time consuming and hard to replace. That why I'm glad the AOS was replaced when I recently had the IMS Solution installed. The mechanic told me it was always easier to install them when the engine is dropped a little with the transmission removed. Basically, you're looking right at it! He also said that it's stupid not to replace it if the engine is ever completely dropped for other work.
okay, I am having a tough time tracking down the part number I need for the vacuum lines. I have 00004320501 based off other threads here (Ahsai). I plug that number in at Sunset, and it is saying that doesn't fit my car. Huh? It's vacuum line, how many different sizes did Porsche decide to use! I probably should get the y connector as well since most likely the lines will be glued in place and be a pain in the neck to get out. Thoughts? Correct part number???
That's exactly what I was thinking unless the hose has been glued to the rubber elbow. OP, I looked up the part on AutoAtlanta and it comes up with the same number you have. Before I order that part, I would take Noz's advice.
Nope, broke in multiple pieces. It was already a tight fit to begin with. Its not a big deal, I will just replace all the lines and possible y connectors. Thanks.
I recall that other folks who were replacing the vacuum lines just bought a big length of generic vacuum line and cut to length...hence the exact measurements in 808Bills picture.
That's what I've done on my other cars. I just went to AutoZone and bought generic vacuum line tubing and it worked great. The important part is getting the right size. Other than that, I don't why you'd have to purchase the Porsche part.
