996 Forum 1999-2005
How many miles on your engine with the original IMS bearing?
Old 02-04-2019, 05:22 PM
JB001
JB001's Avatar
Default How many miles on your engine with the original IMS bearing?
I'm convinced that the 996 engines are liable ones and that the IMS issue has been exaggerated by companies marketing "solutions".
One way to find out if I am right (or wrong) is to ask here: How many miles on your engine with the original IMS bearing?
Mine is a 1999 C2 convertible with 76000 miles.
Old 02-04-2019, 05:33 PM
Mbren1979
Mbren1979's Avatar
0. It wasnt worth it to risk a $20,000 rebuild when while the clutch was being done i could spend the extra $1,000 for piece of mind.
Old 02-04-2019, 05:36 PM
pszikla
pszikla's Avatar
I made it to 122000 miles by the skin of my teeth!
The bearing was so close to failure it was a question of possibly a few miles more before the "big bang".
Mine is a 99 as well, driven "firmly" all of its life including track time.
Old 02-04-2019, 05:44 PM
AzDropTop
AzDropTop's Avatar
02 C4 had 113,000 and the bearing looked good other than having oil in it. Did the clutch, did the bearing. Worth it.
Old 02-04-2019, 05:53 PM
DBJoe996
DBJoe996's Avatar
Received 1,100 Likes on 706 Posts
Daily driver at 143K+ miles 99 C2 manufactured 7/98
Old 02-04-2019, 06:02 PM
Southernman
Southernman's Avatar
Finally! This is a topic I can appreciate:
99 C2 with 90k on original bearing, original clutch, and original RMS. Build date of 3/98.
Old 02-04-2019, 06:29 PM
808Bill
808Bill's Avatar
Just ask the guys that lost their motors do to IMSB failure. If you can't afford a $20K+ rebuild, a $1-2K expense to prevent the failure makes a lot of sense to me.
Roll the dice how ever you like, it your wallet!
Old 02-04-2019, 06:33 PM
JB001
JB001's Avatar
How many miles on your engine before you replaced the IMS?
Old 02-04-2019, 06:35 PM
por944trs
por944trs's Avatar
99’ C2 Cab, 117,000, small amount of wear, replaced because I had already bought bearing.
Old 02-04-2019, 06:36 PM
JB001
JB001's Avatar
The IMS has been a problem for a very small percentage of 996 but reduces the value of all of them. I'm just trying to demonstrate that the 996 is a good car sold way below its' value due to the IMS bad reputation promoted by companies selling "solutions".
Old 02-04-2019, 06:37 PM
Battery Guy
Battery Guy's Avatar
Mine had 71,500 miles on it. The clutch was due, so I had the bearing replaced at the same time. The bearing that came out looked pretty much like new, so certainly it had a bunch more miles left in it. But for peace of mind, I'm still glad that I had it done.
Daryll
Old 02-04-2019, 06:38 PM
808Bill
808Bill's Avatar
Me? I replaced my engine.
JBOO, have you even taken the time to read through the IMSB poll or the other 1000's of IMSB related topics? It's been beaten to death and the creation of another is just not necessary!
Old 02-04-2019, 06:51 PM
Porschetech3
Porschetech3's Avatar
Received 4,359 Likes on 1,972 Posts
99 c2 Coupe 130k original bearing with outer seal removed,Tiptronic daily driver.
99 c2 Cab 70k had stage 1 IMSB failure caught during 2nd gear syncro repair
02 986 90k ...bought after stage 5 IMSB failure (bent valves) put 20k 3.2 "S" motor in..
Old 02-04-2019, 07:18 PM
TexSquirrel
TexSquirrel's Avatar
Received 2,389 Likes on 1,266 Posts
The previous owner of my car had The IMS Solution installed at 33,000 miles.
That means that for 4 years and 19,000 miles he never had to worry about his IMS bearing.
He also had the clutch, RMS, AOS and water pump done.
The car has over double that now on it, and I never leave sleep over my IMS bearing
Old 02-04-2019, 07:29 PM
David993S
David993S's Avatar
Mine was at about 130,000 with no issues, but I installed a new one when I had the engine rebuilt as part of making it a track toy.
Quick Reply: How many miles on your engine with the original IMS bearing?
