IMS Bearing, what would you do?
Some unpleasant news from my Indy today. See pictures below of glitter in and around the IMS bearing and engine case.
Recommendations on how to proceed?
The bearing
Where it lived for 20 years
Its an early build (03/98), 1999 C2 (throttle cable), tiptronic (so no overrevs), black on black. hollow spoke techno wheels, nice interior, 67K miles.
She was new to me in November and saw relatively mild (occasional revs up to 6K when warm) local weekend driving since purchase by me.
I've loved the time I've spent with the car, both driving and wrenching on it to do the easier maintenance jobs (struts, brake pads rotors, engine mounts, fuel/air/cabin/oil filters, belt, oil sump drop, speaker refresh).
Had Indy drop the engine and trans to do AOS, Coolant tank, some hoses, and replace the RMS and IMSB.... thats when we got these pics.
I intend to get some bore scoping done. I wish I could have gotten data on cam deviations and compression tests, but alas, that didn't happen.
I'll know more tomorrow but so far the material was described as fine and glittery. (as opposed to chunky I guess?)
I assume the two main options are:
1) replace it, go with a spin on oil filter and magnet and hope for the best or
2) find an honorable way to get rid of the car.
So, knowing full well that you guys will probably offer a WIDE range of opinions, I'd still be curious to read what you'd do/recommend.
(sadly, writing this felt a bit like writing a eulogy but I can't say I've given up yet. YET.)
The bearing
Vertex FL rebuilt engines as I recall 10k exchange core.
For newbie and future readers oil filter inspection and cam timing deviation might have caught this before engine drop.
So are you 100% certain glitter source is your IMS bearing?
If so the question is how much glitter is inside your engine and where did it go?
With the engine out you can pull off the sump plate and cam covers and investigate, also scope the cylinders and do a leak down test. Probably worth investigating before getting too depressed about your motor.
Fair, should have mentioned I did do oil filter inspection.
It didn't seem significant to me at the time. Not being defensive, I just mean there were a few sparkles but could count them on one hand. (No pics to share of that.)
Prior owner said oil was recently changed though ... so there wasn't much mileage to show up in the filter either probably.
I dropped the sump and there was a fine fuzz of ferrous material on the magnetic drain plug.
Some plastic-y rubbery chunks on the oil pick up, pics attached below.
Welcome guesses as to that stuff too, but academic to the main discussion....
Sorry but it's to late for that motor...Factory short block would be the eco route.
That oil analysis was done when you got the car with fresh oil if I'm reading this right. New oil that showed wear of a 4000k oil sample?
Shameful Thread Killer
Where's the IMSB? Apparently without seeing it, I presume it came out in chunks. What would I do?
1. Flush the engine as much as possible with kero or diesel fuel. Including the oil pump and inlet. If you can remove and clean the oil cooler exchanger do that.
2. Install a full flow oil filter kit and filter, no more bypass.
3. Put in a new IMSB.
4. New oil.
5. Run it for an hour. Change oil/filter.
6. Run it for another hour. Change oil/filter.
7. Hope for the best.
I KNOW of two engines that have suffered metal in the engine and were saved. One was a Boxster, one was a late 996. It's just a matter of how far gone it is.
4. New oil.
Bill, you're killing me. But its a fair question. I honestly have no proof of how old the oil was. I was told it was changed by the seller, but also possible it hadn't.
If you can afford it and have the skills, I’d do a full teardown and inspection at this point. If you decide to sell how close is this car to DFW? I have a truck, can get a trailer and think I might be up to it.
