brake wear sensor
brake wear sensor
My '98 C2 coupe's brake wear sensor came on during a DE last week. Was on during the drive home but the next morning when I went to work it was off. So I am thinking it was an erroneous reading. Two days later on the way to work, it comes back on and remains on for the drive home and the drive to work on day 3. On the way home, day 3, the light is off. I have ordered new pads and sensors because at 120000km I think they have lived a good life, but what is the deal with the indicator? I thought as the pads wore down, the indicator shorted out and signaled the "time to replace". Why do I get a light randomly?
Here is a picture because diagnosis is always easier with a picture!
You didn't really need to have bought new sensors but now you have use them on the new pads. You will find more wear on the front pads than the rear but go ahead and change them all around the car. .
De and track days usually overheat the sensors and they become erratic. I've seen brand new pads and sensors start acting up after just 1 De day. That's most people that do a lot of track time end up just using a jumper to keep the light off.or use track pads with no sensors then switch back to street pads with sensors.
I had an erratic sensor and it turned out that the front pads were down to their limits. Somehow it was a small enough change in thickness that it started to occasionally trigger the sensor. I didn’t think it was possible either. I did a full brake job with new Sebro sensors and all is well.
I had a similar issue. I looked at all of the sensors and none of them were worn through. The problem continued intermittently. Eventually I removed each sensor completely to examine them. One of them had a broken wire on the end that plugs into the car - not the end that plugs into the pads. I replaced that one sensor and all is good.
If you do a search on brake sensors you will find recommendations to zip tie the sensor back or replace with a jumper when you track. I had a replacement set of sensors on the front with my track pads that started to melt from the heat, not rotor contact, so tied back. My track pads, Hawk DCT-60, are too squeaky for the street and I replace with OEM if I plan on doing extensive street driving. Are you using OEM pads for DE?
A lot of folks don't use sensors if they track their car. Especially handy to those that change it to racing pads just for the event. As someone here mention that it is easy to disable them by just shorting the leads. I disabled the sensors too and found just eye-balling the thickness of the pad material works just as good.
Yeah , I know this is an old thread, but it popped up when I did a search.
I have new brakes at all four corners with less than 200 miles on them. This night when I hit a bump in the road, the light came on. Maybe the sensor is kaput? I'll have to take a closer look in the AM.
FWIW, I removed my sensors back in 2004 and haven't thought about them until reading this thread. They were doing the same thing that yours are doing. If you do remove them, you will need to pay attention to your pad wear. As a side note, there may be a time that you decide to run track pads year round. I have been running Pagid Yellows on the street and track forever. One less thing to worry about.
