High Pitched Hum coming from dash-
Also check the rubber seal around your window glass (front and rear, sound can do wacky stuff..)
When this happened to me it was the clear film on my driver's side mirror had started to peel just slightly and had created a harmonic vibration at speed. Disappeared completely when I peeled it off.
Elumere (10-21-2020)
I do have very dated, likely 3M protective film on my hood and mirrors- that could be the culprit Now that I have the Fister exhaust the hmm is not so bad ;>)
So this exact thing has just started happening in my 2002 996 with 281km kilometres on the clock. The noise starts about 120 kmh , stops and starts but does not change pitch and it stays pretty consistent at 140 kph.
Not engine speed dependent at all. I put in the clutch and coasted at 140 kph downhill and the whine stayed constant.
My old clear bra is in tough shape, but I don't think there are any floppy edges....I've been slowly trying to remove it in fact and it is on there really solid. Will check though..
Noise sounds like it's coming from behind center dash vent..hvac on or off. Windows open or closed...
Did you ever figure yours out OP?
Interesting... I have a 40 AE and get this also but only between 95 and 115mph. High pitched whine from dash... So odd.
Are you for real? Where are you driving that you can go 85 mph consistently enough to notice a hum coming from the dash? At 85, things start to get a bit tricky, at least on public roads, and the last thing I think you would be focused on is some nefarious hum.......
Also, have no idea what grommets and "tork" (torx) screws you are talking about.
This might be dumb but is it possible it's coming from spinning from speedometer or other gauge cluster component? Pbly not, right?
Another threads talked about it being a window seal issue and sure enough I had mine changed recently and they installed a one with a more rounded profile.
I ran some experiments last night with painters tape and it looks like this might be my issue. Hard to get up to those speeds multiple times to run the tests so not conclusive yet.
OK so here was my situation- Same humming from the dash area when I would be at 85 MPH the hmm would start. One day I figured out that the below- Windshield Cowl Cover was broken at the passenger side. I has cleaning the window and leaned on it and it moved a decent amount. I found this thread on Rennlist and it was huge help: https://rennlist.com/forums/996-foru...placement.html
WindshieldCowlCover 996-572-563-06-01C
Right CowlCover Screw Cap 996-572-569-01-01C
Left CowlCover Screw Cap 996-572-570-01-01C
WindshieldCowl Gasket 996-572-931-00
HoustonCgrBkr (04-12-2022)
Interesting thanks for the post. My cowl cover does seem pretty solid but I'll check it out.
Interestingly I did notice that one of my wipers seems to have an air deflector and the other does not. Could this be related?
