996 Forum 1999-2005
Water Pump Recommendations?
Old 09-22-2019, 04:20 PM
808Bill
808Bill's Avatar
Default Water Pump Recommendations?
Looks like I have some coolant crust.
What's the latest and greatest water pump?
Old 09-22-2019, 04:54 PM
carlvs
carlvs's Avatar
Default Cheapest pump on eBay
I recently rebuilt my engine and did some elective parts replacing. Alternator and water pump were just some of the parts. I purchased my pump on eBay and the cost was $33.99! Including a new gasket.
My logic is that if the OE water pumps don’t last very long why spend the extra $$$. At this price I can afford to replace the pump at every other oil change if necessary.... The original Porsche water pumps cost between $270.00 and $330.00!
So far so good, I’ve got just over 1,000 miles on the pump and all is well.
Old 09-22-2019, 05:30 PM
Ahmet
Ahmet's Avatar
Have you had bad luck with OE water pumps? I was just thinking how few of them I've seen fail at the shop...
Old 09-22-2019, 06:00 PM
Chris(MA)
Chris(MA)'s Avatar
Water pumps on these cars are kind of a consumable. Go with a reasonably good brand and swap out every 50k miles
carlvs (09-22-2019)
Old 09-22-2019, 08:58 PM
Ahsai
Ahsai's Avatar
I would strongly suggest not using a $33 water pump because basically you're risking your engine whenever it's running. If any blade breaks off and lodges in the heads, it will be difficult to fix.
The following 2 users liked this post by Ahsai:
mrdeezy (09-23-2019), wyovino (09-22-2019)
Old 09-22-2019, 11:12 PM
carlvs
carlvs's Avatar
Default Plastic blades
It is my understanding that the factory pumps use plastic blades and the breaking off of those blades traveling through the cooling system and getting stuck in the cooling passages may have been the cause of some overheating and cracked cylinder heads. This particular pump has metal blades. I intend to check the pump pulley for play at regular intervals and replace the pump as soon as there is any sign of bearing play.
Old 09-22-2019, 11:27 PM
Ponchobroke
Ponchobroke's Avatar
On the other ✋ fiber or plastic blades will erode if they come in contact with the case (in the case of a wobbling/ pre-fail shaft) and not destroy the non-replaceable case. OE are plastic for a reason...
cavediver32043 (06-07-2020)
Old 09-23-2019, 12:12 AM
Ahsai
Ahsai's Avatar
Oh no, metal blade is even worse.
Old 09-23-2019, 12:15 AM
Ahsai
Ahsai's Avatar
Precisely
Old 09-23-2019, 04:35 AM
mrdeezy
mrdeezy's Avatar
The risk on these cars �� are to great ���� to use junk �� parts.
Old 09-23-2019, 09:19 AM
Scott at Team Harco
Just a car guy
Scott at Team Harco's Avatar
I ordered mine from Rock Auto. It's listed as Hella, but it's a Pierburg. Was a bit over $200.
And of course - the really smart guys are going to call it a junk part.
The following 3 users liked this post by Scott at Team Harco:
808Bill (09-23-2019), carlvs (09-23-2019), DSC800 (11-14-2020)
Old 09-23-2019, 09:31 AM
carlvs
carlvs's Avatar
Default Plastic impellers
Unfortunately the plastic blades just don’t erode they also brake off and the broken pieces get lodged in narrow water passages especially in the cylinder heads. That’s where the problems can occur, blocked passages lead to localized overheating and then cracked cylinder heads. You can’t win! Pick your poison...
Old 09-23-2019, 11:19 AM
Nickshu
Nickshu's Avatar
Pierberg is the Porsche supplier...same pump just not in a Porsche box and no Porsche P/N stamped on it.
Avoid the metal impeller pumps...Porsche made them plastic so if/when the bearing fails the impeller won't dig into the aluminum engine block (the water jacket opposite the impeller is part of the engine block).
Old 09-23-2019, 11:50 AM
NYoutftr
NYoutftr's Avatar
^^THIS^^
Old 09-23-2019, 11:51 AM
NYoutftr
NYoutftr's Avatar
Bill
I will send you a link where I got my Factory Porsche parts
David
The following 2 users liked this post by NYoutftr:
Quick Reply: Water Pump Recommendations?
