Replacement M96 DIY engines under 10k
I thought I would throw together a basic path that would satisfy many DIY'ers for a 3.4 and also for a 3.6 M96.
Costs include a factory short block, sending the heads to a head service, complete gasket kit with all seals /o-rings/bolts ect. plus Loctite 5900. ( actually will have a few seals left over like front/rear main, water pump)
Head service would include cleaning, pressure testing, basic 3 angle valve job, new seals, light machining to ensure trueness cost is normally $250 each head..YMMV
This would take care of the engine internals, of course any worn out external parts coils,plugs, AOS ect, repair as necessary..
And you supply the labor.
M96/01 /02 /04 from 99-2001 3.4
996-100-951-TX Porsche factory short block from Auto Atlanta $6305.60
996-105-253-00 Vario cam guides from Auto Atlanta $21.66 need 2 sets
#1364363-M9601SET complete gasket set/bolts ect. from AutohausAZ $475.25
Part# 000-043-204-35-M258 Loctite 5900 from Pelican parts $14.00
$6838.26 parts
$500.00 cylinder head service
Total $7338.26 + your labor
M96/03 2002-2004 3.6
996100996UX Porsche factory short block from Auto Atlanta $7669.08
100904202 - O.E.M. M96.03 SET complete gasket set / bolts ect from Pelican Parts $660.75
$8343.83 parts
Total $8843.83 + your labor
A much better alternative than buying a used engine IMHO
$6838.26 parts
$8343.83 parts
The following 15 users liked this post by Porschetech3:
808Bill (10-23-2019),
996.2 (10-23-2019),
cbracerx (12-11-2019),
Dr_Strangelove (10-23-2019),
fourblades (10-31-2019),
and 10 others liked this post.
So on the short block,, Just thinking here..
If I bought a set of nickies with pistons, and reused the rotating assembly except for bearings, I think I'd be in that ballpark?
As long as my current engine passed inspection that is..
And I'd add and IMS update of one sort or another most likely. so add the ~1800 dollar bump..
Porschetech3 (10-22-2019)
Its sort of the basic, and a light upgrade option,, you'd always have to be ready for that un salvageable bit,,
Scored crank or bad IMS shaft , unuseable cams,, etc.
The nickies option would also give you a diy 3.8 upgrade if you wanted..
At some point,, you also still have to decide your abilities.. "A mans got to know his limitations" LOL
Where I live in the Bay Area, there is no machine shop that will do a valve job on the heads for $500. It would be $2,000 minimum.
Shipping that short block from Atlanta to San Francisco is $500 at least, could be more.
Don't forget oil, gear oil, coolant, brake fluid, etc... and filters.
I don't see it for less than 10K, maybe 11K.
Nickies DIY for M96/01 /02 /04 years 99-2001
Nickies for 3.4 3.6 3.8 from LN $4995.00 (includes pistons/pins/rings/clips)
Part # 996-105-170-53-M48 Iwis cam to cam chain From Pelican Parts $21.00 x2
Part# 996-105-177-53-M48 Iwis long chain from Pelican parts $56.50 x2
Part# 996-105-171-55-INT Iwis IMS chain from Pelican $28.00
Part# 996-105-175-52-M260 chain guide (primary)From Pelican parts $28.25 x2
Part# 996-105-173-52-M260 chain guide (secondary) from Pelican parts $28.50 x2
Part# 996-105-165-55-M100 IMS chain rail from Pelican parts $38.25
Part# 996-105-166-51-M100 IMS guide from Pelican parts $46.25
Part# 10-0124-125-M3020 LN/RND IMSB from Pelican parts $733.50
Part# 996-101-115-62-M100 carrier bolts from Pelican parts $6.25 x14
Part# 996-101-205-10-M100 main bearings from Pelican $ 8.25 x14
Part# 996-103-121-62-M100 rod bearings from Pelican $8.25 x12
Part# 996-101-129-52-M100 thrust bearing from Pelican $14.50 x2
Part# 900-041-004-01-OEM IMS chain guide clip $1.00
Part# 204-6301 Rod bolts from ARP $222.69
$7196.76 parts Total
$500.00 head service
$ 7696.76 + your labor
Not much more than the Factory short block, this is the way to go if you have the Skilz !!!!
The following 6 users liked this post by Porschetech3:
Chris Back (12-11-2019),
EVOMMM (12-02-2021),
islaTurbine (10-23-2019),
moburki (10-23-2019),
Os7213 (10-23-2019),
and 1 others liked this post.
Heads truly will depend on the condition,, despite all the myth and legend, not all Porsche bits are special..
Doing the heads on a 911 is no harder than Subaru heads.. boxer is a boxer especially with overhead cams.
The price can go high,, new valves will drive it up, if any seats are bad.. Guides etc..
but I have access to the tools so for that bit its parts only.. keeping this as a budget
estimate yea should allow for the higher end and hopefully get lucky.
I'm also not going to try and replicate a FSI engine,, I tip my hat to their experience and ability to optimize end to end..
I’d consider adding having a machine shop check the crank and rods for the nickies option. Both need to be checked for size, concentricity, etc. Assuming you can reuse them might be okay, but I’d rather be certain. Having the rods prepped for ARP rod bolts might be reasonable too. 7,000 rpm isn’t a joke.
Definitely,, luckily that's not a real expensive thing to do.
Dropping all the cams in a "Cam DR " to check they are straight as well.
Same with the IMS.
I'd prob end up paying 2 hours to one of the shops locally to check for straight and magneflux the crank.
Same with the IMS.
I've had a 4" hole in the side of a aluminum block that went into a cylinder filled and welded and
sleeved, it did another 3 seasons till a new rookie driver decided that 10K rpm's just wasn't good enough..
Aluminum is amazing ..
Porschetech3 (10-23-2019)
Cost of engine rebuild.
$6838.26 parts
$8343.83 parts
$6838.26 parts
$8343.83 parts
The total came to $7,700.00
Here is a link to the spreadsheet. http://www.ez-bizwebs.com/3.4/images/Spreadsheet/Porsche996_EngineRebuild2.pdf
I would replace all of the valve seats as part of the refurb just due to that being a mode of failure.
mlemche (12-02-2021)
