Cabracer - Track/Autocross/Weekend Warrior build
Hi guys!
New here, and excited to be a new owner of a 2000 C2 Cabriolet with just 72k miles.
The purpose of this car is to be a weekend toy car to take to HPDE, Autocross, Canyon Carving and general weekend warrior!
Making more power on these NA engines seem tough so I’ll be going the reverse and losing weight by removing as much as my creature comforts will permit. The spirit of the unbuild is a GT3-esque wannabe with lightweight over crazy power. After all the GT3 only has 55 more hp than this model, and is also 6speed RWD. Same universe, different galaxy.
I unfortunately can’t weigh the car in Quarantine but the range I can find online is from 2,904 to 3,197 pounds. That’s quite a range, and I’m guessing the higher end is for C4 or Turbo models or Tiptronic models. (Once we’re free from quarantine, I’ll get it weighed properly and update the calculations.
My car has VERY limited options. Heck, the left side option buttons of the center console are all blank buttons... so I’m taking this car is on the lighter end. It does have Sat/NAV, and 18” wheels, but that’s the only thing extra I can find.
So I’m guesstimating this car to start at 3070 lbs.
Hope you enjoy the build (or the un-building?). Also thinking of making this a YouTube channel/series, would that be interesting to anyone or would I be self-humoring myself?
Starting Weight: ~3070lbs
-15 lbs: Spare and Tools in Frunk
3 -20 lbs: Sat Nav/Radio, Sat Nav CD holder, Lower console trim, 4 speakers
14 - 30 lbs: Removed front carpet. The sound deadening material is heavier than you think! We had a week of rain here a few weeks ago and learned that my top has a leak somewhere Found some water in the foot wells.
-25.2 lbs: Rear seats are out
-18.5 lbs: Rear carpet + 4 floor mats
66 -45 lbs: Muffler Bypass
Coming soon:
- Front Seats (~40lbs?)
Current weight: ~2915lbs
Coup - Cab = +165 lbs
C2 - C4 = +122 lbs
6 speed - Tip = +99 lbs
3.4l ( MY01) - 3.6l ( MY02 ) = +55 lbs
3.6l C4 - C4S = +153 lbs
Turbo Look Solid Spoke wheels ( 17" is stock ):
7.5" x 18" = 24.91 lbs
10" x 18" = 29.32 lbs
18" 5 Spoke Carrera wheels:
8" x 18" = 20.50 lbs
10" x 18" = 22.70 lbs
A 10.03 lb difference
C2 - C4 = +122 lbs
Coming soon:
The following 2 users liked this post by Cabracer:
djm68 (05-25-2020),
Ratchet1025 (04-25-2020)
Congrats! Weird photo...makes it look as though the left side of the car is bigger/fatter/heavier and sort of drooping, or the right side has been pushed in somehow... I sure it's an illusion caused by the photo but it still looks somewhat bizarre... Just sayin' Good luck with the (un)build!
Last night, I pulled out the radio/sat Nav, lower center console with Sat Nav CD compartments (there were still CD’s inside and it works!!), side leather and carpeted trim pieces. My hand scale estimates this at about ~20 pounds all together.
I’ll be keeping AC as I live in San Diego, and 10-20 days a year, top down is too hot for me. So I’ll relocate the Temp control to the upper center console, and do a delete of the lower. It gives me more knee space as well.
Next will be removing the 6 speakers (2 on dash, 2 on doors, 2 in rear inner quarter panel. I took the rears out to clean the water drains and man they are not light!
Am I missing any? Is there an Amp somewhere? Cables to each speaker worth pulling out? Seem to be behind trim, which is behind plastic, which is behind carpet.
Is there a radio/sound control unit somewhere, or does it go from radio to cables to speakers?
Let’s lose some weight!!
Sat nav w/ CD, lower console trim, lower console covers. Space Grey
Another angle. The driveway is lightly graded, so the right side is slightly elevated.
And not sure if my phone is playing games with me (Galaxy S9+). Pretty good camera but idk.
I also feel the passenger side motor mount is shot, so will be replacing/fixing that. It does make the right side exhaust droop ~1cm so I’m sure that doesn’t help the illusion.
^^^ That ones much better - it's partially a perspective thing (the closer side looking larger and foreshortened) but I think the angle/grade of the driveway also has a lot to do with the illusion. Yes, your motor mounts look to be hanging low. As long as you're making it a semi-track-car you might want to got with the WEVO or RENNLINE or RSS semi solid motor mounts.There are a few threads (understatement) on the merits/drawbacks of them, that you'll probably want to check out.
San Diego?
I saw the Texas plate and was about to ask what part of TX.
I won't ask since I know that San Diego TX is down near Corpus Christi.
I actually used to live in Dallas.
But the car and I are both in San Diego now. We moved separately lol.
I doubt you are starting at 3000lbs, probably more like 3200. Either way...
This is what I have done to a .2 cab with similar goal in mind. I have not weighed it since doing all of this but guess I am around 3100-3150 with 1/4 tank fuel. (.2 is little heavier than a .1)
REMOVED
floor mars, rear seat tops, bottoms and seat belts, spare tire and tool kit, mufflers and muffler brackets, stock drivers seat, lead battery, factory radio, stock wheels, stock springs and front camber plates.
ADDED
rennline track mats, lithium battery, sparco bucket seat, 6 point harness, rollbar, Carplay radio, lighter BC Forged wheels and RE-71 tires, Tarrett caliper studs and front camber plates, HR sport springs, FVD oil baffle, ims solution, Ferodo DS2500 pads and steel brake lines.
I think thats all of it., if not its pretty close. Either way, I am probably around 3150. Rollbar and harness add weight back in that you take out. I am taking it to its inaugural track event next weekend.
Enjoy your build and know it gets expensive! Its a lot of fun though and worth it! If you want to really take weight out, remove the soft top completely and associate motors. I bet that gets you 100-150lbs off.
REMOVED
ADDED
The following 2 users liked this post by JSETarga:
Cabracer (04-25-2020),
OP - do you plan on putting in a rollbar if you will be taking it to the track? That is going to add weight. Several clubs will not let you run without.
REMOVED
ADDED
REMOVED
ADDED
A roof vs a soft top mechanicals and I'm sure some additional reinforcements for rigidity.
I like your list. Will save it for reference. I'll be living with a few less creature comforts than you
New to porsche but not to racing. Have lots of experiencing losing money in cars and racing lol. Hence going on a diet vs adding power for this car.
So that's a dilemma for me. The factory roll bar seems safe from the few rollovers I've researched. If I did add an aftermarket one, I'd remove the factory ones to offset the weight. Yes some clubs will not permit without but most that I'll be running with here in Socal do. TBD for now. If I do, it'll be a standout color, like a gt3 orange >
