Clutch slave cylinder or clutch on backwards?
Dad and I were doing work on the car and had to remove transmission. Everything was put together and my car refused to go into gear with the engine running.
Bled the slave cylinder and was able to get the car to shift when both wheels were off ground, but when on the ground it still refuses to go into gear.
Clutch doesn't seem to be engaging as even with the pedal to the floor we still get wheel movement when lifted. So we're assuming either the friction plate went in backwards or the slave cylinder isn't properly engaging.
No noise from the clutch and the slave seems to be actuating so confused as to what the problem might be. Don't want to drop transmission again if slave is the problem.
Oh no leaks either so pretty confused. Wouldn't a backwards clutch make a load of noise? Wouldn't a bad slave cylinder be leaking and would it go bad between the time we removed the transmission and the reinstall process? I know it was a challenge to reinstall and had to put a lot of pressure on it to go back in.
This would be very hard if not impossible to put the friction plate in backwards. The screws holding the DMF would prevent the friction plate from making contact with the DMF during installation. This would of been a huge red flag and the pressure plate would have fought you putting it on. My bet is air in the line to the slave cylinder.
I have seen someone who put the clutch disk in backwards, and it was just as you described.
Clutch pedal "felt" normal, but would not release the disk, when clutch pedal depressed.
Second time removing the trans doesn't take as long as the first...
Thanks everyone for the responses! We ended up just ordering another slave cylinder since it was relatively low cost and easy to replace.
So we're going to give that a shot first and if it doesn't work then drop the transmission again.
Strangely enough my slave cylinder only had one bolt holding it to the transmission. We ended up installing two bolts but when thinking about what may have gone wrong my dad had the theory that maybe it's an alignment issue which is why the slave only had one bolt. What if it had to be positioned in a way where only one bolt would allow it to make contact properly with the clutch fork? Not sure but just grasping for ideas until we try this out.
If it does require dropping the transmission then so be it, but would be nice if it's something more simple.
Hmmmm
I have been dealing with the same problem. My slave cylinder overextended and poped the plunger out, losing the fluid. I have had it apart and back together 3 times, and it did the same thing to the new slave cylinder. Everything went together smoothly but won't go in gear when running. I don't know how you replaced it as it slides over the drive shaft. I now have the whole bellhousing and clutch out trying to figure it out. No luck so far.
Clutch doesn't seem to be engaging as even with the pedal to the floor we still get wheel movement when lifted. So we're assuming either the friction plate went in backwards or the slave cylinder isn't properly engaging galderma tri-luma cream reviews.
