Wheel Spacers
Wheel Spacers
Hello All, new Porsche owner here, Wondering what is the ideal size wheel spacers for my 2001 996 C2 . It has the stock 17 inch rim & tire size and they appear to be way inside the fender wells. thank you in advance for whatever help you can provide. B.
You'll love this answer! It depends...on your wheel offset and tires. Oh...and how conservative or boy racer you want to look. Lots of folks have measured up the gap with a ruler and gone from there. If you want to get tighter than that for $40 ECS rents (buy and then return for credit towards spacers) a kit that has 5 spacers from 1mm to 15mm so that you can find your best fit.
https://www.ecstuning.com/b-ecs-part...202ecs03lktkt/
No affiliation, but once I get my suspension setup this is the path I've been considering.
One more thought, for what you're going to spend on spacers for 17" wheels, you may just want to wait until you're replacing rubber and move up to 18s. Fills out the wheel wells much better, keeps the stock look if you're after that, better ride and better sidewall protection than 19s, and 18" tires are still aplenty.
Dukesracer42 (07-06-2020)
Here is a pic of my car that has 11" wheels with offset of 63mm.
https://rennlist.com/forums/996-foru...l#&gid=1&pid=1
I also have 5 mm spacers. So that makes it the equivalent of 58mm offset. If you give me the offset and the wheel width I would be happy to calculate the wheel spacer you need to match my car. However, I will say that if you plan to go with wheel spacers I would first go with 18" wheels instead....I almost feel that with 17" wheels the stock offset looks better because the wheels are smaller. JMO.
Basic Sponsor
Hey Guys,
We offer High Quality Porsche specific Wheel Spacer Kits sizes 5mm all the way up to 40mm. All or kits include the Proper Extended Porsche Type Lug bolts. We are currently offering 10% off at checkout with coupon code "RENNLIST"
You can check out our user friendly website www.4wheelspacers.com
We also offer Free Shipping! when you purchase 2 Kits!
If you guys need any help or advice on getting the correct wheel spacer sizes for your Porsche, you can PM me anytime and i will be glad to help.
Thank you
Thank you
4WheelSpacers Your #1 Source For The Best European Wheel Spacers and Adapters -SUMMER SALE ON LOTS OF PRODUCTS - QUALITY HUB CENTRIC WHEEL SPACER KITS FOR AUDI, BMW, MBZ, PORSCHE, VW 5MM UP TO 40MM !!!
EMAIL: INFO@4WHEELSPACERS.COM
WEBSITE: WWW.4WHEELSPACERS.COM
paddlefoot64 (07-03-2020)
Received 1,100 Likes
Hey Guys,
Thank you
Thank you
I have 15mm at all four corners with the 18" Turbo Twists. No rubbing and it's lowered on coilovers.
So I have a question about spacers that has been bugging me, so here goes. If a spacer is added, that means that the wheel center line is no longer in the original place with respect to the wheel bearing. And so the weight of the load is off center for the bearing. Would that result in more load being on the edges of the bearing rather than centered on the bearing, and is that somehow bad, would it cause premature wear of the bearing or any other similar risks. I know the "shift" of the load center is small, a few millimeters, but is that so small that it doesn't really matter that the load is offset? Thanks!
Basic Sponsor
Hope this answered your question.
Regards!
Well thank you everyone for your time and responses, No worries, I'm not insulted by the "boy racer" comment given my username. I currently race formula cars and have been called dukes since I was about five years old so it just stuck.
So Don't think I'm going 18s and new rubber since its not a keeper for me, already looking at 9974S. I am doing some easy inexpensive mods just for appearance, reliability and IMS for confidence when selling next spring. I will absolutely check out ECS . Thinking someone has the exact same car, rims and tires given there stock and knows exactly what looks best on this, But not looking to rub fender wells either.thanks again.
