Side light out
Side light out
hi guys. I am having probs with my driver side front side light. First turn switch on my lights but the front driver side does not light up. Everything else is fine heads high/low beams, spot lights turn signals Front and rear. Just the front side light On the second photo with the screw driver pointing I think there is a bulb that has blown. I put a tester across the points and it is open. On the working front passenger side one it is bridged.
so I suspect I should change that bulb but dammed if I can get into it. My big question is. are they sealed beams on these lights and do I have to change the whole left front unit shown in the first photo.
I hope some of you have come across the same problem I am having and can help me out here thanks in advance.
Ok guys I solved it. There was a small bulb under the screw driver. I had to use small mole grips to get the socket out and replace with new side bulb. Thanks anyway guys.
