SNS Engine Rebuild
#61
I didn't catch it and may have missed it, but what assembly lube are you using? Does Jake recommend a particular assembly lube? They are not all created equal.
I really love all the nice photos and work. It appears you are doing a nice clean and diligent job. This will serve you well!
I followed Jake's general recommendations for using high viscosity lubricant and engine assembly grease where he advised. I ended up using a couple of lube products including these:
#62
Jake - for people that have some familiarity on assembly lubes and pre start procedures on other engine types that have worked for them in the past - would you say that largely, if it’s worked for you and you have developed trust in it in the past, you should be good - or - are the qualities with these engines that dictate more specialized assembly lubricants and pre-start procedures ?
#63
Former Vendor
Doing this method is about the only huge mistake that can be made, other than just starting the engine up with npc procedure in place to achieve OP the first time.
A pre- oiler is a good idea, but not everyone has one.
#65
Appreciate the kind words. Has been a very gratifying process. I have been sharing pics with my siblings...my oldest brother, who had a Porsche 1600 Normal back in the 60's, has always commented back to me...I just want to drive it when you are done!
BTW - Bay Area - I grew up in Novato and my bro is in San Raphael. I really love that part of CA.
golock911 (06-09-2021)
#66
keeping on
Assembling the fuel rail I've run into a block getting the injectors into the rail. I moved into the work believing it would be pretty straightforward as I have replaced fuel injectors while the engine was in the car....but nope, I am having a bear of a time seating the injectors in the rail such that the clip is properly attached. Will just keep at it and try not to break stuff!
#67
You need to wet the O-rings with something. You can use fuel or vaseline.
#68
Realized I was trying to get the clip into the wrong groove - Here we go!
#69
Achieving oil pressure is easier than people make it out to be. The people that have issues will pull the DME relay, and spark plugs, and turn the engine on the starter till OP is gained. The starter turns these engines over too slowly to achieve this.
Awesome followup Jake!
#71
The following 2 users liked this post by De Jeeper:
Porschetech3 (10-09-2021),
SoundnSpeed (10-11-2021)
#72
Too many things to enjoy and do!
one pic is of my family (siblings) closing our summer shack on a lake...brothers, one sister a bunch of nephews and me and my oldest.
#73
Looks fun. Residential construction is my day job so ill never post pics of renovations . I can appreciate all the other things that steal our time.
#74
Ha, De Jeeper you must cringe at my sequence on the bathroom remodel, I know I do at times! Material delays hit me all over the head and shoulders on this one.
#75
It certainly makes me cringe...brings back memories of my bathroom remodel 5 years ago. 200+ large format (1' x 2') tiles for the shower and only 5 didn't need custom cuts. Felt like I was in jail for a few weeks.
