Another 99 cold start tick
I have the same issue on my 99. Only notice it in the winter (MN). Goes away shortly after the cars warms up. I don’t stress about it.
Follow my directions and "listen" to the cats using a Stethoscope.
Elumere (03-06-2021)
Same
My car has a noticeable tick in the morning at cold start. If I do nothing it will continue ticking. If I rev to 1500 for 15-20 seconds then the tick is gone/diminished. Coming mostly form drivers side. Once warmed up, no longer there or noticeable.
Car has just under 62k miles. IMS replaced 20k miles ago. Otherwise drives very well.
I just changed oil to 0w40 (was 15w50), had water pump and serpentine belt replaced along with bank 1 side chain tensioner. Oil filter was clean.
any thoughts?
any thoughts?
has a ton of upgrades and honesty I don’t know if it has a tune or original engine. I am a retired motor oil guy, I used to evaluate engine oil testing data and formulate motor oils. Anyway I will be doing some used oil analysis on my car, since I used to take care of 2 million dollar engines used
at mines all over the world I can really do this. Any of you guys use any kind of engine oil additive, cylinder coating stuff???
To an automotive troubleshooter, a "noise is a noise", the hard part is finding/duplicating noise and finding the root cause, usually the fix is simple.....
