Spin on filter and viscosity
LN mentions to use at most 5w40 with the spin on adapter. Porsche has been pushing 5w50 for a little while now with their own product. I picked up a case of M1 5w50 to try. Is the spin on filter going to create an issue with flow with the higher warm viscosity??
https://rennlist.com/forums/996-foru...er-woes-2.html
I currently have the OEM plastic filter on my car and the POs all used the same for 68k , I dont see it changing it on my next oil change
I do know that LN recommends the use of DT40 for the M96 and DI40 for direct injection engines starting with the 997. They also recommend Motul Xcess 8100 if A40 is of concern.
I have the spin-on filter and used the Porsche oil and others ands it was all fine.
M422A1 (02-22-2024)
If you run one of the longer alternate filters listed that have increased filter surface area or a billet washable filter with a higher micron element, this should not be an issue.
I do also want to reiterate not to use a 10w60 in these engines.
The following 3 users liked this post by Charles Navarro:
