Hit a HUGE pothole, bent wheel, I have questions...
Hit a huge pothole while I was out Sunday and now my left front wheel is bent, not terribly, but the vibration is not so good. I will be filing a claim with USAA.
Options:
1. Live with the vibration - don't think so
2. Repair the bend - this wheel has already been repaired twice before, I don't think it can handle another repair
3. Buy one exact used wheel - no guarantee it's not bent either
4. Buy one new wheel from Porsche, $1,136.32, and it's on back order, no idea when available.
5. Buy four new aftermarket wheels, $????
Question: Are there any aftermarket 18" wheels that don't add any weight but don't bend so easily? This is the fourth incident in three years where I have a bent wheel for one reason or another.
They are 18" Carrera II wheels from the factory on a 03 C2.
Thoughts...suggestions...humor?
Options:
Forged aluminum wheels are expensive and a monoblock CCW might be something to consider.
sasilverbullet (11-17-2021)
I can’t say for certain but I believe the OEM wheels are cast or similar technology. I have a set of OZs which are a flow formed and super light but aren’t as robust. Forged monoblocks start as a block of metal and then are milled(CNC’d). Forged wheels are generally stronger. CCW is a brand that came to mind but BBS, Volk and higher end wheels have forged options.
The following 5 users liked this post by SoCal911t:
Billup (11-18-2021),
nacra258 (11-19-2021),
sasilverbullet (11-18-2021),
SSDVC (11-18-2021),
Trimsarctic996 (11-19-2021)
Options:
Options:
Try these guys...
https://www.originalwheels.com/porsche-wheels/911.php
or: https://www.wheelcollision.com/store/PORSCHE.asp
Ebay may be your best bet for 1 wheel. Worst case, you may have to get it worked on, but it's a better option than your current wheel. Many folks have two sets of wheels which gives them an option to switch wheels "just in case" as well as run two sets of tires. Never an easy decision.
Once you figure out what to do for a wheel, you can try running a higher profile tire. May help to absorb the shock a bit better. Many guys are running 35 instead of 30 in the back. Don't know what has been attempted in the front with 18s.
I’ve been to Wheel Collision Center more than I’d like.
Had a few repairs done there and also had them source a wheel after a large pothole made it unrepairable.
I was really happy with their work and would definitely recommend them.
The following 2 users liked this post by philbert996:
dporto (11-18-2021),
Stop hitting potholes ! (humor)
Try these guys...
Try these guys...
Thanks for the links! I will probably get a wheel from one of those guys.
What you should care about is weight....more weight - so that it's a stronger wheel. You will be hitting more potholes no matter how hard you try not to. You are not standing behind the car pushing it, so what do you give a crap if the wheels are a bit heavier? They will roll just the same.
I'm going to be looking for stronger, lighter wheels first, then if too expensive I'll probably just get another 18" Carrera II wheel. Still researching...
This is the very reason I removed my mint sport classic rims and purchased a moderately priced aftermarket wheel .... If I bend one of my rims no big deal I just buy another for $500 and my oem rims stay nice and mint.
Yeah, I have two sets of 5 spoke classics. It's always good to know you can swap one out "just-in-case".
