So I have this bra...
Over the past 20 years I have had the PPF on my car and replaced it 2x. I will replace it again over the next year or so. I highly recommend it.
You never really know it's there unless you look very closely and boy does it save your paint from flying debris. I keep my car in my garage, so it doesn't sit out in the sun or in bad weather on a daily basis, so I haven't seen any yellowing. I replace it when there are one too many marks that develop from being hit by flying road stuff.
My guess is that Florida heat may impact the usable life of PPF, so if you go that route, talk to people/shops that have it and how much heat and sun they get on their cars. PPF helps, but it will not stop large rocks and FOD from causing damage.
Bras have all the negative effects cited by others. Both the car and the bra need to be clean on the inside and don't let them get wet. Also, a loose fitting bra can cause wear on the paint.
I just had my bumper and hood resprayed for the second time after 140K miles. I figure the cost of a respray is less than PPF.
Elumere (03-18-2022)
Woah! That has seen some bad days.
Yep, my bet is that if the car lives outdoors in all types of weather for its life, it will be a mess to get off. I have kept mine garaged and you wouldn't know the PPF is 7 years old. I'll get a picture tomorrow in the daylight. Don't know if the 3rd removal will be a problem. It may be. The paint is 20 years old after all. To the points made, don't know if it's better to just run it without and get it repainted every so often after the car is chipped. At the end of the day, we will all need a respray unless you just sit your car in storage. What fun is that?
I use one on the track and it certainly makes post track clean-up easier and protects from stone chips. Speed lingerie looks much better IMHO than the traditional black.
It was a two step nightmare. It took 10-15 hours to remove the 'film' and another 10-15 hours to remove the residual adhesive. Until this, I had never heard of plastic razor blades which made the job a little easier.
In this pic you can see the film is removed around the crest but still has adhesive residue.
I guess you could argue that it did its job because it did look good when it was finally all removed.
GC996 (03-19-2022)
