IMS Solution Installation Cost
I was looking to get an IMS solution installed in a 2004 996 C4S, the shop quoted me $1900 CAD for R&R transmission and and $600 to grind out the bellhousing/install the bearing along with the other parts. I'll be supplying the IMS solution myself. Does this seem like a reasonable price to get it installed?
I had this done in Canada in 2018 and can give you details on cost. I also used a previously certified installer. You don't have enough posts to PM tho. LMK how I can provide you more info if you are interested.
I would also consider budget for other things like RMS, AOS, likely flywheel and clutch.
What do you think of the costs, am I around that range or a bit higher? The car has 34k kms on it so I don't expect it to need a new flywheel and clutch.
adding as a friend doesn't work. Happy to have a chat with you. I'm in Toronto. Post your contact info if you are comfortable or wait to have enough posts to PM.
Find a new shop. The engine case has to be notched to accommodate the oil fed line that goes to bearing, not the bell housing. And $600 to notch the engine case is ridiculous. It’s a 30 minute job, tops.
dporto (02-13-2024)
zbomb (05-13-2022)
nexus77241 (05-10-2022)
$2,500 Canadian is around $1,900 US which sounds reasonable.
I’d be more concerned about their experience working on the 996 and how many IMS Solutions they’ve installed.
To me that’s more important than saving a few dollars and going to the low bidder.
I paid right at $2250 US in labor for IMS Solution, RMS, AOS, Clutch and oil change this time last year at an LN certified installer so that included the pre-certification stuff as well.
The following 3 users liked this post by hoofdpijn:
