EPS IMS Bearing
To make matters worse, they created a method to extract the Large Single Row 6305 IMS bearing on post 2006 engines. This a bearing that doesn't need to be extracted in the first place because it has very few reports of failure and is proven to handle the load of the M9X engine. Common sense would tell you that attempting to enlarge the IMS port by grinding into the case would introduce horrible amounts of metal shaving inside the case. What could go wrong?
Unfortunately there are enough shops out there that are stupid enough to carry this procedure out and why we make a repair sleeve to bush the block back to a standard IMS flange housing bore diameter after the engine has to come apart to be rebuilt when it fails following the boring procedure to change the 06-08 bearing out:
https://lnengineering.com/products/t...ng-sleeve.html
Petza914 (07-07-2023)
However much the conspiracy theorists believe that threads "disappear" into the ether, being a paid sponsor of Rennlist does not give us or any other vendor the ability to have this done. It's all there good, bad, and indifferent. Just use the "search" button.
The following 7 users liked this post by Charles Navarro:
996-CAB (07-06-2023),
allcool (07-06-2023),
Porschetech3 (07-07-2023),
SeanPatrick31 (07-07-2023),
Spastblast (01-17-2024),
and 2 others liked this post.
The following 4 users liked this post by wildbilly32:
Rather than take your word for it, I went ahead and searched. There aren’t many and yes you’re right they are around so I stand corrected.
If you do go with the EPS bearing, be sure to not punch a hole in the shaft to oil it. The ims has a freeze plug on the oil pump side that serves two purposes - one is to keep oil out of the tube, and two, to keep the oil pump drive captive. We've seen that plug fall out and the oil pump drive fall into the shaft, causing a complete loss of oil pressure. Lastly, the oil pump drives are known to fail with spirited use, so putting one that is notched with a stress riser the whole length of it is a bad idea.
As they say, the shaft (and bearing) is submerged in engine oil. No need for additional oiling. I'm sure their offering the oiling option was to attract potential DOF buyers who do not understand that the M96 engine is wet sump and by design, the shaft sits at the bottom of the engine and is bathed in oil.
I’ve recently become aware of the European Parts Solution IMS bearing and wondering why no one seems to talk about it. It’s touted as a permanent solution to the M96 IMS issue and comes with a five year/30k mi. warranty. This cylindrical roller bearing apparently has twelve times the load capacity of ball bearings and utilizes the bearing cage for lateral thrust loads which has always been the weak point of roller bearings. It also has a provision for pressure fed oiling by punching a hole in the rearward part of the IMS in front of the oil pump and adding a slotted oil pump drive shaft, but the website strangely walks that back stating that it’s not necessary because the bearing is constantly bathed in oil. it seems like a pretty ingenious solution without the need for the oil filter adapter and external oil feed lines of the LN IMS Solution. It’s also $579 instead of $1800. Has anyone had any experience with this product? It seems like a viable option when considering the LN and other products out there…
I would do this job once with The IMS Solution and never even worry about it for the rest of my life since I keep my Porsches forever.
The following 6 users liked this post by Petza914:
996-CAB (07-07-2023),
Coolwnc (07-07-2023),
jobyt (07-07-2023),
ltusler (07-10-2023),
philbert996 (07-07-2023),
and 1 others liked this post.
One thing that kinda slips by is that the "solution" isn't anything exotic, its basically the same as a cam bearing in a Chewy V8..
The weakness the IM shaft has had is poor thrust control, cranks have a thrust bearing surface in most engines, same with cams,
all implemented in whatever method the manufacturer chose. Had Porsche simple made the IMS look like a cam with 3 or 4
pressure fed bearings and had one dedicated thrust surface on two bearings they never would have had a problem.
I have the solution cause it made sense to me, and it was part of the rebuild I was already committed to.
I thought the IMS bearing was something you just replaced.
After doing some researching the IMS Solution was the only replacement that made sense.
Do it once and you’re done and less moving parts.
The only downside was the cost.
Is there any other reason not to use the Solution?
wildbilly32 (07-07-2023)
ZuffenZeus (07-15-2023)
TexSquirrel (07-13-2023)
Even if you're pessimistic, the solution say is a 100K mile option, most of the basic bearing replacements, are a 50-75K mile option.
the ROI seems within reason..
Personally, on my car—when the time comes for an engine tear down and rebuild to a 4.0 with Nickies- I’ll be doing the IMS solution and calling it a day and never looking back.
My current 997.1 I bought has the EPS roller from prior owner and I do like the design a lot also and it will remain in for the foreseeable future. I believe it has over 25k on it now-no issues whatsoever. They did not do the punch in the oil pump shaft- I wouldn’t prefer that method with this product either. (Also my car is an early 05- so I have the serviceable single row bearing)- so replacing is straight forward. I’m sure if it was an 06 or newer the factory bearing would’ve handled the task to this point.
Between the ball bearing and roller- I prefer the roller for our cars- whether it be EPS or RND, with a slight nod to the EPS.
Just my preference, not looking for a heated debate.
The IMS solution from LN does appear to be the most long term/forever solution, much like the design in the mezger engines.
I think for the most part either way you’ll go- you should have fairly good luck.
Most importantly make sure you have a seasoned installer who can properly install any of the products correctly. Half the time you see early issues with any retro IMS bearings, you gotta wonder if it was caused by a botched install?
Personally never looked too close at the DOF solutions, so can’t weigh in here.
Don't discount the extra $1000 for the Solution vs. the Retrofit. You are buying a 20 year old car and it's unlikely that the bearing and clutch are all you need to do, once you get it up on the lift. My 996 went from the Porsche dealer to my Indy by trailer where I had already scheduled the IMS bearing, clutch, RMS but my Indy made up a large needs list including brakes, struts, AC lines, mufflers, 4 new tires, bent wheels that needed to be straightened, etc. That extra $1000 and more went to other needed repairs. The Solution was out of the question. That being said, I don't have any anxiety at all about the Retrofit. Sure, it is going to get replaced in four years at the expected end of life, and the Solution will go in, but I will have more money by then, and it gives me years to plan its next Spa day.
Carlo D (07-15-2023)
For more on the EPS and it isn't good, scroll through this active thread: https://rennlist.com/forums/996-foru...l-row-ims.html
I see a single example of an EPS failure, out of context, from an allegedly non-neutral source, followed by reports of failure from LN products.
All this means is no solution is perfect, be it from EPS or LN (or FVD, Pelican, etc.).
I will admit the oil feed mod from EPS seems like a bad idea and my car will not be getting it.
RL does appear to be very cautious in regards to EPS (or any non-LN IMSB product for that matter), I haven’t had the same feeling on other forums which tend to show EPS in a quite positive light.
TheChunkNorris (07-13-2023)
My 996.2 came with The IMS Solution already installed back in 2013.
When the engine was rebuilt, 9 years(52K miles) later, the IMS Solution was reused.
I'm hopeful it will be a lifetime+ part...mine, and hopefully one of my kids...maybe even my grandkids.
The following 5 users liked this post by TexSquirrel:
Haalex (07-14-2023),
ltusler (07-14-2023),
pdxmotorhead (07-14-2023),
wildbilly32 (07-13-2023),
