Lightweight Flywheel
Hi all
Just curious for those with a LWFW - do you get extra chatter/noise when pulling away in high gear at low revs?
My LWFW appears to have an exhaust type vibration when in the 'wrong gear'
That might be a harmonic issue that will eventually lead to a broken crankshaft. I'd be willing to bet dollars to doughnuts that you experience some vibrations at certain revs that 'smooth out' above that range regardless of gear...might want to think about going back to a dual mass flywheel.
Yes with a LWFW you will get a lot of transmission noise when you "lug" the engine . Same sound you will get it if the dual mass flywheels locks up/ fails..
You will also get a lot of clatter in the transmission in neutral with the clutch out at idle..
Alfred, what's your goal with adding the LWFW?
Most people when given the choice will chose to replace the dual mass flywheel when this occurs just for the noise alone even though they could continue to drive the car with the harmonic vibrations undampened and be the same "risk" as a LWFW but without the weight reduction/increased engine braking
Harmonic vibration is a very scientific subject and can have very unexpected behaviors , have you ever dealt with harmonic vibrations??
Alfred996c2 (09-25-2023)
Interesting - I haven't dealt with Harmonic Vibrations before.
The car came with a LWFW so just something I am getting used to. I suppose the question is, should I change it to a DMFW?
I am getting used to the noise of it, and its fun to drive with the faster changing rev ranges - I just want to check I am not causing damage in high gears at low revs
If the above is a normal characteristic then I suppose there is more to get used to with the car....
It came with the car...... I liked driving with it on the test drive - but we didn't sit in traffic when the car was warm so I never noticed the chatter.
I am used to it now, but want to check what the best/most suited driving style is for a LWFW
My 3.6 in my Boxster S has a LWFW . But when the engine was built all the rotating mass was balanced to race spec . I do get gear clatter at idle with foot off the clutch . Other than that I have never noticed any additional noise . The race balance makes a huge difference .
frederickcook87 (09-25-2023)
I would like to know how it would perform with a fluid dampener on the front.
Unless they are fully balanced during a rebuild. Also you will have gear chatter at idle with clutch out.
