My 911 has a Cylinder Misfire
I have a 99' 911 and yesterday when I started the car I felt an engine misfire.
Connected my OBDII meter and code P0301 appeared Cyl 1 Misfire
Does that usually indicate a Spark Plug or Coil issue?
Mileage=106,000
Bought car recently and I have no maint records.
Probably should change all 6 plugs and coils but at this time I'm only going to change coil and plug on Cylinder 1 and hopefully the code wont reappear ...
Process of elimination, I like it ...
I'm wondering how difficult is it to change cylinder 1 plug and coil.
I think cylinder 1 is on the drivers side, cylinder facing the rear bumper ...
3 4
2 5
1 6
3 4
2 5
1 6
You could very well have a leaking coolant expansion tank also which is above it. Mine had cracked coil packs, then combine that with a leaking coolant expansion tank that drips, you get the misfire.
Only get the Porsche replacement tank, unless of course, you want to do it more than once.
It’s entirely possible that changing plugs and/or coils results in no change to the code (doesn’t fix the issue). However, if these plugs and coils are super old or in poor condition, go ahead and “check the box,” but there’s no replacement for good, old, troubleshooting either.
Yes, it is a bit finicky getting at #1 (and #6) but not impossible with a good tool set. I just upgraded mine to the 997 style and it took about an hour to do all 6 of them.
2 5
1 6
This is my 1st Porsche but most other sports cars I've owned it was easier to get to the plugs facing you Vs the ones facing the firewall but I'll soon find out first hand ...
2 5
1 6
Received 1,101 Likes
Did you not see my post? And, no plugs face the firewall, but you will have to remove the heat shields and work your way around the exhaust system. The old coil packs with the inset bolt heads are difficult to remove. But the upgraded 997 coil packs are easy to install with a 10mm wrench. Good luck...
