Best technique and scope for "Bore Scoping"
I look to see what it will tell me.....
I've seen so much when looking in M96 sumps. From a little soot to heavy sludge, from a little plastic bits of different colors to melted plastic parts from over-heating, from no metalic particles to huge amounts of metal parts, from little pieces of silicone to large gobs of silicone , some springs, clips and other odd or foreign objects.., water, gas, and antifreeze, of course what I like to see is NOTHING but clean fresh oil ..
allcool (04-12-2024)
Porschetech3 (04-14-2024)
Thanks for sharing the video. Is this method only possible for the 4-6 bank? I’ve scoped my engine both from the plug holes and the sump. Sump was difficult access and plug holes don’t tell the full story. Would you describe your subject engine as “bore scored”?
Bank 1 has three things going for it...1 . the water pump and inlet from the radiator is on that side so bank 1 get coolant first.....2 the Thrust side of the cylinder is the bottom side on the exhaust side and has gravity fore to help lubricate it....3... the piston pin is offset .5mm to the intake side which lowers thrust forces on the cylinder...
Bank 2 has 4 strikes against it...1. the water pump and inlet from the radiator is on the other bank so the coolant has to pass through the Sump to get to bank 2 which heated it up.. 2 the oil heat exchanger is mounted on the bank 2 side and transfers the hot oil heat to the coolant on that side.. 3 ..the thrust side of the cylinder is the upper/top/intake side and gravity force works against keeping lubrication on it.. 4 .. the piston offset is .5mm to the intake side which increses the thrust load because the thrust load on Bank 2 is on the intake side...( Porsche did not make the pistons bank specific) ...
So in light of all that I don't worry about bank 1 unless something specificaly directs me there.
No that engine would not be considered as bore scored....those small scratches are probably from a failing IMSB that was caught very early but the debris did some damage,or just some silicone particles that have came loose from the Lokasil and made a light scratch as it washed out and into the oil and drained .....
The following 4 users liked this post by Porschetech3:
I don't worry about Bank 1 cyl 1-2-3 .....yes it only works for Bank 2 cyl 4-5-6...every time I have seen any scoring on bank 1 it also had scoring on bank 2 so....
Porschetech3 (04-15-2024)
Porschetech3 (04-16-2024)
The following 3 users liked this post by JTT:
thanks guys, I feel like I am so busey but it is just old age because I don't get anywhere near as much done in the same amount of time as I used to which is frustrating ...But the feedback and satisfaction is the only reason I keep doing it....
I will second that we never see bore scoring on bank one without bank two already being horribly scored. That's not to say you might find some sort of other damage or wear caused by something being ingested, but scoring on bank one without bank two is not likely.
The following 3 users liked this post by Charles Navarro:
