Best technique and scope for "Bore Scoping"
I have mentioned this several times before but the word just doesn't get spread very well.....I keep seeing the recommended Bore scope being either from the Sump or from the spark plugs holes..
Here is my newest Bore Scope I just got and using the proceedure to just remove the access plug for the wrist pins then you can get a good look at the bottoms of cyl 4-5-6 in just minutes without even draining the oil...
The Bore Scope is a Vevor brand and has a 6mm lens with "articulating head" and cost about $100 ....( yes it's made in China like most everything now) ..Has a 5 inch screen a 1 meter length probe and 8x zoom and 3 light brighteess for the LED...Very clear picture and automatic focus...
Here is a video of the whole proceedure in just a few minutes... and a pic of the acccess port for the wrist pins.. :
Note the picture is upside down, the engine is on a stand. It is an engine I bought years ago for $2500 has 100k miles... was a good running engine was only pulled because the shop was doing a wild body kit and engine swap and had no need for the engine... I just bought to have around as a "just incase" I actally have 2 m96/01s on engines stands, this one and a fresh rebuilt one I've had for 17 years "just in case."...
The following 9 users liked this post by Porschetech3:
allcool (04-12-2024),
Charles Navarro (04-12-2024),
dporto (04-12-2024),
JTT (04-12-2024),
KeyWest996 (04-12-2024),
and 4 others liked this post.
This is a nice easy option. I did try it after you initially told me about it a while back. Worked great and was MUCH easier. My borescope doesn’t have the articulating head, so in my case I was somewhat limited, but still got a good glimpse.
Porschetech3 (04-12-2024)
Pt3, Very nice... I'll try that soon, thanks for sharing.
I don't care for scoping from underneath in the sump. Maybe if i had the $$$$ snapon scope then I could actually see whats going on in there good enough to satisfy me to make a correct call on bore score. Ya, suppose if bore score was real bad it would easily be apparent. But a mild case with a few scores here and there, not so easy for me to see. Not to mention the contortions needed to get at all cylinders sufficiently to see the complete condition while getting oil dripped on the lens and me.
Ya, the pin plug method seems much better.
Skip's method is a good option, but it is still a good idea to drop the sump on any engine you are inspecting, especially during a PPI. You'd be surprised what people have found in the sump on running engines that had no symptoms.
The following 4 users liked this post by Charles Navarro:
My favorite thing to do on an "unknown engine"...
Skip, will this method work on 997 models, either 997.1 or DFI .2 models?
Nice job! Nice borescope too. Looks to be cheaper than the one I got, which has an articulating head but needs a smartphone for a screen.
https://www.amazon.com/gp/product/B0BQLPB8VS
Yeah...at first I wasn't crazy at having the screen as a removable part of the tool and 32g Micro Memory card for the video's and pictures...You have to pop out the memory card and place it in a thumb drive reader USB to transfer to laptop or post them......But that is just so easy and everything stays together that after I used it, I realy like it that way..
Then clean it all up nice. A very little sealer tacked up with my fingers in a quantity that never seeps/squeezes out at the seam. doesn't take a lot to seal a perfectly flat clean surface. I've tried to explain that unsuccessfully to many other techs that squeeze out a bead all around a part and slap it together...
@Charles Navarro absoluty !!! Looking at whats in the Sump is the best way to get a look into the whole heart of the engine , and so much can be learned about the engine as a whole from that view...
School me, what do you look for...?
