Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat
Go Back   Rennlist Discussion Forums > Water Cooled Technical Discussion Areas > 996 Forum
Sign in using an external account
Register Forgot Password?
Thread Tools Search this Thread
Old 05-05-2005, 10:17 PM   #1
Rob in WA
Cap'n Insane the Engorged
Rob in WA's Avatar
Default Weight Shavings - Optima Battery
My battery was dying, so I decided to install an Optima Red Top. Optimas are gel type batteries, so there's not all that fluid sloshing around. They also weigh 13 lbs less then the OEM battery (38 lbs vs. 51 lbs). I was going use the install method that Oggie on L.I. wrote up on renntech, but I couldn't find 3/8" thick high density polyethylene anywhere. I decided to just modify the OEM battery tray; basically drill two holes in it. I was able to install an entire stereo w/out ever drilling a hole in the car, but I had to for the battery. I figure it's a replaceable and relatively cheap part if someone ever wanted it back to completely stock.
I just drilled two holes in the OEM tray and two holes in the base of the Optima, then I ran bolts with lock nuts through them to secure it. I also had to bend the bracket on the side a bit to get it to sit flush.
On the other side I was able to slide the base of the Optima into the groove that the OEM battery fits in.
All installed, as long as it's centered the existing cables reach, otherwise you need to get the reverse polarity Optima - or extend the cables.
MY01 C4 Cab
MY82 911SC Targa - gone, had her ten years
MY08 Touareg
MY01 Beetle TDi - son's
MY99 A4 - wifey's
Rob in WA is offline   Reply With Quote
Old 05-06-2005, 08:11 PM   #2
Carrera Mike
Carrera Mike's Avatar
Good JoB! I replaced my Porsche Batt on my 993 with Optima. Loved it. 10lbs is substantial weight savings.
Carrera Mike
Photos & DIYs
PCA First Settlers Region
Carrera Mike is offline   Reply With Quote
Old 05-06-2005, 09:10 PM   #3
Oggie (on L.I.)
User
Oggie (on L.I.)'s Avatar
Nice job, Rob. Interesting about the reverse-polarity. After I installed mine, I was thinking that the reverse-polarity version just makes it a longer stretch for one side while making it an easier stretch for the other. Even with the reverse version, my battery cables barely made it. At least you didn't have to get longer battery cables, as some had suggested in the past.
Finding the polyethylene is definitely a bit tough. I think a piece of Lexan would do just fine. I think it can be drilled and cut easily without chipping -- unlike plexiglass, which chips very easily.
Say, did you make sure you used stainless steel screws and bolts?
Oggie (on L.I.) is offline   Reply With Quote
Old 05-06-2005, 10:00 PM   #4
Rob in WA
Rob in WA's Avatar
Hi Oggie Your instructions are excellent. In case anyone's interested HERE'S A LINK. I called both places listed (and quite a few around town) and was unable to locate 3/8" thick high density polyethylene - www.plasteak.com had a 5/8" thick piece, but I understand that wouldn't fit in the OEM battery tray grooves. I'm not sure if the screws and bolts I used are stainless steel, I just had them laying around. I now see from looking more closely at your instructions that you specify stainless. What's the purpose? The only contact is with the plastic portion of the Optima and the battery tray, which has foam underneath.
MY01 C4 Cab
MY08 Touareg
MY99 A4 - wifey's
Old 05-07-2005, 10:50 AM   #5
Oggie (on L.I.)
User
Quote:
Originally Posted by Rob in WA
Hi Oggie I now see from looking more closely at your instructions that you specify stainless. What's the purpose? The only contact is with the plastic portion of the Optima and the battery tray, which has foam underneath.
As long as no water gets in there, you're ok. With the Optima, there's no worry about spilled battery fluid since it's sealed.
Tags
911, 986, 993, battery, boxster, carrera, gel, installing, optima, plastic, porsche, racing, savings, trays, weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
Copyright © 1998 - 2007 Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
Emails & Contact Details
