Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat
marketplace | store
Go Back   Rennlist Discussion Forums > Water Cooled Technical Discussion Areas > 996 Forum
New! Use your Facebook to securely log into this site, click logo to login
Old 05-24-2005, 09:52 PM   #1
JimPDX
User
JimPDX's Avatar
Default Itzkirb's garage door opener Mod
Just did the mod and have it installed works fine...
Question how do you tap into the power on the window buttons so you can get the garage button to lite up?
The existing Porsche connector (one white and one black) leaves little room to slide anything in there on the two end posts of the window switch...any suggestions?
ItzKirb said he was going to do it...but I haven't heard or seen anything about about it ...
Thx
Jim
JimPDX is offline   Reply With Quote
Old 05-24-2005, 11:08 PM   #2
kilrgt
kilrgt's Avatar
its the 2 outside posts, i cant remember but i just tapped in to the power lock button, i simpley spliced into them.
08 SL550 -daily
04 TT ...... FVD stage IIII..and lots of other mods
04 C2 with some mods... SOLD
RML-----041222-5461
kilrgt is offline   Reply With Quote
Old 05-25-2005, 01:31 AM   #3
Mitty
User
Mitty's Avatar
Well done! I gotta do this mod too.
The rest of Itzkirb's mods/pics.
Mitty is offline   Reply With Quote
Old 05-25-2005, 02:37 AM   #4
JimPDX
User
JimPDX's Avatar
Quote:
Originally Posted by Mitty
Darrin...
What kind of garage door opener do you have?
The prep takes about a half an hour for soldering the wire leads to the board and about 15 minutes to install...
If you do the mod make sure you mask off the traces on the board before you solder. I didn't take any soldering classes in law skool so I'm not real good but I did get it done...also make sure that before you put the board into the center console to install a new battery and cover the board with a good cloth tape...like gaffer's tape...thus, preventing any possibility of shorting if the board touches metal.
Right now I don't have any power going to the switch for the light because I don't want to cut and splice into the line...so, I'm still trying to figure a way to bring the power to the new switch from another location.
I have the part number for the switch...the one that Kirb referenced for the Targa is a matte finish. Its not available in gloss finish like we have in our cars...so I used another one...Its $33.00 at Sunset.
If you need any help let me know...
Jim
Old 05-25-2005, 02:39 AM   #5
leedav
leedav's Avatar
Jim,
My car had an ashtray light that I disconnected when I removed the ashtray. If yours had one that connector should be powered whenever the car is on.
Lee
2004 996 AS/BK "Paulina"
USM030, Xe, ShShft, Bose, Clr Sd Mrks/Brk Lght, V1,
Alum Gge Fcs, 6mm/15mm whl spcrs, SpoilerSwtch,
GHL Mflrs, CF shft/brk, Htd Lthr Sts w/Crst,
Dual Tips, Thk Str Whl, Slvr Whl/Hd Crsts
__________________________________________
Other rides: '02 325i, '05 Yukon XL
Prev Rides: '98 M3, '91 Miata, '69 Fiat 850
Prev Track Cars: Spec RX7, SRF
leedav is offline   Reply With Quote
Old 05-25-2005, 03:45 AM   #6
Itzkirb
Super User
Itzkirb's Avatar
Always glad when my DIY can help someone out. All i Did to light the switch up was jam wire into the back of the Power Window switch and then taped it up. I know it's not very professional, but no one sees it and it works.
Itzkirb is offline   Reply With Quote
Old 05-25-2005, 01:54 PM   #7
Chrisp3
Can someone please post the link to this mod. I thought I had already done this but can't find it on my machine anymore.
Chrisp3 is offline   Reply With Quote
Old 05-25-2005, 01:56 PM   #8
Itzkirb
Super User
Itzkirb's Avatar
check 4 posts up....
or my sig below...
Old 05-25-2005, 02:04 PM   #9
Chrisp3
Thanks! I really blew it! Never saw the link in the post above. Sorry to trojuble you guy's
Old 05-25-2005, 02:39 PM   #10
JimPDX
User
JimPDX's Avatar
Quote:
OK...there is the window switch and the connector to the window switch (one black one white)...
Am I understanding you correctly then that you took a wire and attached it to the window switch posts on both sides of the window switch and not into or onto the connector which brings power to the window switch?
BTW what gage wire did you use to bring power back to the G/door switch from the window switch?
Thx...
Good mod...
Jim
Old 05-25-2005, 03:02 PM   #11
Itzkirb
Super User
Itzkirb's Avatar
If you look on the back of the connectors to the window switch you can see some room for a wire to slide in. I just took the right outer post of the Garage Door switch and taped it into the right outer post of the Window switch conncetor...did the same with the left outer switch.
I used a really thick gauge wire since that is what i had laying around. You can use a thin wire I assume since the factory wires are pretty thin.
Hope that helps?
Old 05-25-2005, 03:14 PM   #12
Riad
Take My Avatar, Please
Riad's Avatar
Send a message via AIM to Riad
My damn garage door motor keeps flaking out on me. My mod would have to be a monkey in the trunk that runs out and opens the door for me.
2004 Carrera 4S Cabriolet Seal Grey/Black
2001 Carrera 4 Black/Graphite Grey - Gone but not forgotten
2004 Lexus Rolling Sponge Wifemobile/Deer Slayer
I Was Placed On This Earth To Put Off Doing Something Extraordinary.
Riad is offline   Reply With Quote
Old 05-25-2005, 03:16 PM   #13
leedav
leedav's Avatar
Last I saw the trunk monkey he was working as an anti-theft device.
Lee
Old 05-25-2005, 03:59 PM   #14
RLandis
User
RLandis's Avatar
Riad, put an 1176 on that monkey, and squash him to death!!!!j
Lee, glad the picture is back!!!!!
RLandis is offline   Reply With Quote
Old 05-25-2005, 04:18 PM   #15
Mitty
User
Mitty's Avatar
Sorry to derail the thread, but while you and Kirby are figuring out switch wiring, Trunk Monkey videos here..
-Darren
Tags
996, 99661311910a05, buy, car, door, garage, itzkirb, mod, mods, opener, porsche
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Contact Us - Rennlist Discussion Forums -
Privacy Statement - Top
Powered by vBulletin®
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 1998 - 2007 Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
