classifieds |
membership |
rennlist |
photo album     sponsors | upload photo | chat | marketplace     |
| Register | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | My Recent Topics | Vendor Directory |
Thread Tools |
#1 |
User
Hi all, I'm a long time lurker with a high mileage (85K) '99 996 that has recently developed a pretty noticeable engine tick that actually seems to get a little louder when the engine gets warm, and it doesn't go away. The car runs fine and pulls great. My trusted independent mechanic says no worries, it's just lifter noise which isn't a problem. Just want to get your opinions, should I believe him or am I in for a new engine soon? thnx in advance.
#2 |
Super User
Are you sure it is lifters and not a noisey EGR valve? That valve will click continuiously sometimes. It is the valve directly above the alternator.
#3 |
User
it is the EGR, should I be worried? the ticking is constant, not rapid at idle but gets more rapid up and down with acceleration and deceleration. Thanks
#4 |
Super User
That is normal opertation for the EGR valve. Not to worry. So much for trusting your mechanic. Glad he didn't suggest tearing apart the engine to install new lifters....only to have the noise continue after he was done.
#5 |
User
Now I can spend my dough on more mods
#6 |
User
Nice work 1999Porsche911. I know a lot about my MY 99 but you've got answers to stuff that would have left me scratchin' my head.
#7 |
Lifetime Rennlist Member Join Date: Jul 2003
Porsche tech says it could be a debri in the hydraulic lifters that partialy blocking full flow of the hyd fluid to properly lift the valves.
#8 |
User
and changed the oil hoping it would help, which it didn't. If it is the valve lifters, I wonder if a higher oil viscosity might work.
#9 |
Rennlist Member Join Date: Oct 2004
I know on the 993 that this is not uncommon and due to a partially collapsed lifter. If it is a lifter and it is always noisy, then replacement is the only fix. Everything else is just a band-aid that falls off.
Does anyone else know if the 996 has had a history of failing lifters? Marv |
#10 |
User
Is this a serious issue? Do you guys think I need to take care of it asap, or can I wait a bit?
thanks |
#11 | |
Super User
Quote:
#12 |
Rennlist Member Join Date: Jan 2005
Is the EGR system located where you can get at it with the engine running? If it is, you can use a long socket extension as a stethoscope. Compare the noise there to the noise at the valve cover (or use a real stethoscope). You should be able to localize the noise.
Lee 2004 996 AS/BK "Paulina" USM030, Xe, ShShft, Bose, Clr Sd Mrks/Brk Lght, V1, Alum Gge Fcs, 6mm/15mm whl spcrs, SpoilerSwtch, GHL Mflrs, CF shft/brk, Htd Lthr Sts w/Crst, Dual Tips, Thk Str Whl, Slvr Whl/Hd Crsts __________________________________________ Other rides: '02 325i, '05 Yukon XL Prev Rides: '98 M3, '91 Miata, '69 Fiat 850 Prev Track Cars: Spec RX7, SRF |
#13 | |
Super User
Quote:
#14 |
User
1999porsche911, would you be able to tell me where the connector is located at in the bay? Thanks again for all your assistance.
#15 | |
Super User
Quote:
When you hear the ticking sound from your engine, stop, open the trunk, disconnect the valve connector (with engine running). If the ticking stops, you have found the noise maker. |
| Tags |
| 996, constant, lifter, lifters, noise, porsche, stop, ticking, valve, warm |
| Thread Tools | |
