fun weekend project - pep boys muffler bypass pipe
#62
Russ, those muffler bypass pipes look great. You're giving me ideas. My quad exhaust on a narrowbody might be had for cheap if I take your approach. Thanks for posting the pictures.
Originally Posted by Russ Murphy
Here's the result of my muffler bypass project. I didn't want to throw down 6 bills or whatever it is currently for the Fabspeeds, but have decided I want 40-50 lbs less on the car at the track, so I ordered two 90 degree stainless steel mandrel bends from Summit Racing and two Magnaflow polished stainless double wall round tip (both in 2 1/4") took them to a muffler shop and had them barely flare the end that goes onto the cat and weld the tips on(not a great job on the welding). I finished them with the angle grinder with 3M scotchbrite velcro pads and voila.... two pounds a piece and a total of $140 all told. So you can get something nicer than the Pep Boys version without too much trouble.
#63
Originally Posted by ga911
Russ -
Do you have the Summit part number for the 90 degree pipe? They have about 300 SKU's in s/s alone. Thanks.
Jim,
So add the set screw to back things up. Thanks.
#65
it looks like the summit part is no longer available. Can someone please post the exact size of the pipe needed? I have found similar pipes online but need to make sure i order the correect size (especially lengthwise)
thanks.
thanks.
#66
guys would they work for 997s?
similar 90 degrees 2 inch pipes?
can someone also tell me why we cant use the pep boys pipes for long term?
other than the looks of it, i reckon they work same like fabspeed?
If it looks ugly, cant we weld some nicer looking pipes on it?
