Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat
Go Back   Rennlist Discussion Forums > Water Cooled Technical Discussion Areas > 996 Forum
Sign in using an external account
Register Forgot Password?
Search
Thread Tools Search this Thread
Old 04-07-2006, 09:06 PM   #1
Jeremy B
User
Jeremy B's Avatar
Default Rattle at Idle???
I previously posted about a rattle when I shut the engine off, But hadn't noticed it at idle before. Now yesterday I noticed that only when the car is warm I hear a rattle, but as soon as i touch the gas it goes away, It's very puzzeling, again it doesn't do it when it's cold, or when I'm driving only, when idling. Any thoughts? also anyone have any opinions on tining the windows? doea anyone like or hate the way it looks?
Drjeremyb
To remove this ad, register today or login if you already are registered!
Jeremy B is offline   Reply With Quote
Old 04-08-2006, 03:52 AM   #2
ElTorrente
User
ElTorrente's Avatar
My car rattles from the retractable spoiler at idle sometimes. I confirmed it by pushing on the upper right corner of the retracted spoiler and it went away. I told the shop when I had it serviced, and they lubricated it, and it sorta seemed to help, but that sound is back now.
It only rattles when I have the air conditioning turned off, since when the AC is on, the idle is slightly different and a little smoother.
ElTorrente is offline   Reply With Quote
Old 04-08-2006, 01:29 PM   #3
Jeremy B
User
Jeremy B's Avatar
Thanks for the tip, I checked that this morning, but unfortunately it wasn't that, I was hopeing it was that simple, I does sound like its coming from teh muffler, but since everything is in there so tight, its hard to tell, I'm going to use a rubber mallet and tap on the mufflers to see if I can reproduce it. If anyone has any other info, thanks in advance.
Drjeremyb
Old 04-08-2006, 11:16 PM   #4
Armando Ramirez
User
Armando Ramirez's Avatar
Have you noticed if it goes away when you put the clutch in ?.....
Gear noise tends to sound like an exaust rattle....you really notice it with a light weight fly wheel.
I would not expect it to go away if it is out of gear and your noise is gear noise...
So make note noise with: Car in gear and or out?
Armando Ramirez is offline   Reply With Quote
Old 04-09-2006, 06:01 AM   #5
Peter B
Peter B's Avatar
Could it be a loose baffle plate inside the silencer box? Try putting something over the exhaust tip on the rattle side of the engine. If the rattle stops it probably means a new box. I had trouble with both boxes on a 98 car. Found nearly new boxes at a local porsche aftermarket specialist for a fraction of the OPC price!
'95 C4 with mega miles & lots of smiles.
Peter B is offline   Reply With Quote
Old 04-09-2006, 12:08 PM   #6
Jeremy B
User
Jeremy B's Avatar
Thanks guys, tried those tips too, and I didn't notice a change, tried puching the clutch in and tried covering the exhast tips on each side as well, no change, oh man, hope it's not serious, it's just wierd that it goes away right after idle, I figured it can't be a valve or crank, owuldn't that goet alittle louder or faster off idle, but maybe I'm wrong?
Old 04-10-2006, 03:21 AM   #7
Armando Ramirez
User
Ok so it makes this noise at idle......
get out of the car and try and find it....open up engine compartment...
there is a mechanics tool that looks like a thesisscope (spelling) only with a long prob at the end....
use that if its inside the engine....if its outside...you should be able to track it down easy on a lift.
Paid Advertisement
Tags
996, air, car, conditioning, idle, porsche, rattle, rattles, slight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
Copyright ę 1998 - 2007 Rennlist.com
Advertise on Rennlist - Privacy Statement - Terms of Service - Jobs
Emails & Contact Details
