Window doesn't go down when open/shuting door
Out of the blue my passenger window no longer drops down the inch or so when opening/closing the door in my 2000 996 C4 Cab. So basically it won't shut unless I lower it prior to closing the door because the window hits the lower edge of the convertible top. Anyone else have this problem or know how to fix it? The window still works fine when I hit the power switch, just doesn't do it automatically.
Newbies Hospitality Director
Troy - I think there was a thread on this topic a couple of months ago, but I can't recall what the "fix" was. You might want to do a Search on "window."
Thanks. I'll run through the old threads and see if I can't find something on it and check on the other items too. It's very frustrating that I can't open/close the door with the top on without having to drop the window down.
Originally Posted by an02boxster
I would look at the limit switches for the wind up position.
Originally Posted by Patric F.
Window regulator.
I've got a slightly different variation of this problem. drivers side window will not lower. the switch will not lower it, the convertable top won't lower it, nor will either the inner door handle or outer door handle. it won't drop the 1/2" or lower all the way down. when i use the switch i can hear the solinoid in the door flipping on and off when trying to raise the window but not when trying to lower it. the voltage is dropping when trying to raise or lower it. does'nt matter if the engine is on or off door open or closed. any ideas where to look first?
sounds like the window motor. i have one for sale. :-)
It could also be that the regulator cable has completely come out of the guides due to a broken plastic guide wheel. Best bet if it's a DIY scenario is to remove the door panel and check it out. The regulator's not hard to replace and while not cheap it isn't too bad as far as the price goes.
I was going to search this morning for this issue. Glad I didn't revive an old thread!
My 03 coupe drivers window is really pissing me off. when I pull the door handle it does lower but when I release the handle it goes back up.
Is this the microswitch as well? Everything is functioning, just not the way I want. Can't shut the damn door with the windows all the way up.
For what it's worth, I have the same problem as well. The owner of the shop fixing the issue told me that you can figure out the cause by trying to push the window down with your hand. If it drops, the regulator needs to be replaced. If not, he told me it is likely the microswitch.
Rocky Mountain High
It's a fairly easy DIY - the hardest part is taking off the door panel without scratching the leather.
no squeeking on this one and pushing down manually does not budge the window. leading up to this, the window did it a couple times and restarting the motor cleared it up but no such luck this time.
i'm questioning if i should be going after the dash switch or the door as i'm not sure how the power for this is routed.
its odd that it is both the 1/2" drop as well as the whole range of lowering the window that is out.
