996 Forum 1999-2005
Speedometer calibration?
Old 05-16-2022, 10:24 AM
Carlo_Carrera
Carlo_Carrera's Avatar
Received 2,285 Likes on 1,460 Posts
Reviving this old thread.
I bumped it up to first page so someone who is looking for it can see it.
Old 05-16-2022, 12:44 PM
mhoefer
3rd Gear
mhoefer's Avatar
My 2003 Targa has 285/30R18 on rear, 225/40R18 front. It has upgraded stock 18” Porsche rims. My build sheet shows the 18s. Is this the correct tire size or could I go a bit bigger? Incidentally, I am off reading low by 7 Kmh at 100 Kph. Is there a programmer I can use to address this, speed app on my phone and Waze both verify, digital speed signs also.
Old 05-16-2022, 12:45 PM
mhoefer
3rd Gear
mhoefer's Avatar
I did confirm, for the 18" rim upgrade my car has stock, these are the correct size tires front and back. Still, 7 Kph off seems a lot, programmer?
Old 05-16-2022, 01:52 PM
5CHN3LL
5CHN3LL's Avatar
I don't know about newer Corvettes, but on my '96 C4, I had to use the HyperTech PPIII to change adjust the speedo for the gearing differences when I swapped the D33 for a D44 with 3.73 gearing. Maybe newer cars with built-in GPS can auto-calibrate, but my older Corvette definitely needed to be tweaked. The digital speedo now perfectly matches GPS-indicated speed...
As far as the 996 - my 996 has ALWAYS indicated a few MPH faster than actual speed using the digital and analog gauges. I thought this was a known issue/fact about the 996 - there are countless threads on the Interwebs about it. As far as I know, there is no way to correct for this. An old thread in this very forum from 2013 (https://rennlist.com/forums/996-foru...naccuracy.html) suggests "European regulations mandate that speedos not show less than actual. So european cars have built in errors ( - 3mph) to comply."
Originally Posted by Gramps
If Vette recalibrates itself, how come the Hypertech Power programmer advertises that it can be used to calibrate for wheel/tire size changes?
Old 05-16-2022, 01:55 PM
TheChunkNorris
TheChunkNorris's Avatar
Received 1,860 Likes on 898 Posts
Originally Posted by 5CHN3LL
I don't know about newer Corvettes, but on my '96 C4, I had to use the HyperTech PPIII to change adjust the speedo for the gearing differences when I swapped the D33 for a D44 with 3.73 gearing. Maybe newer cars with built-in GPS can auto-correct, but my older Corvette definitely needed to be tweaked. The digital speedo now perfectly matches GPS-indicated speed...
As far as the 996 - my 996 has ALWAYS indicated a few MPH faster than actual speed using the digital and analog gauges. I thought this was a known issue/fact about the 996 - there are countless threads on the Interwebs about it; as far as I know, there is no way to correct this.
That dude posted that 20yrs ago.
Old 05-16-2022, 02:12 PM
5CHN3LL
5CHN3LL's Avatar
<edit>
don't pay attention to the village idiot.
Also, I'm the village idiot...too dumb to know I got necrothreaded. I'l be in the corner counting my thumbs if anyone needs me.
</edit>
2022 - 2013 is 9 the last time I checked...
Regardless, the internet is awash with similar posts.
https://www.theglobeandmail.com/glob...ticle11487709/
https://www.northamericanmotoring.co...-accuracy.html
https://www.caranddriver.com/feature...meter-scandal/
Old 05-16-2022, 02:41 PM
TheChunkNorris
I get you, I'm just saying the quote you replied to was posted in 2002... I don't think that person is going to see that.
Old 05-16-2022, 04:43 PM
5CHN3LL
5CHN3LL's Avatar
Ah, f@ck. What you meant to say is "Schnell, you're a moron."
TheChunkNorris (05-16-2022)
Old 05-16-2022, 05:39 PM
TheChunkNorris
Not even close.
Old 05-16-2022, 09:15 PM
Mike Murphy
Mike Murphy's Avatar
Received 1,589 Likes on 993 Posts
Originally Posted by mhoefer;[url=tel:18146395
18146395]I did confirm, for the 18" rim upgrade my car has stock, these are the correct size tires front and back. Still, 7 Kph off seems a lot, programmer?
Your 7kph difference is within the 3-5MPH range of most 996 owners, but is your speedometer reporting 7kph higher than you are actually traveling, or is your car traveling 7kph faster than what the speedometer is showing? If the latter, then I would think that’s a bit odd.
The wheel and tire sizes on my car, I believe, are stock.
Wheels & Tires Sizes:
Front 225/40ZR18
Rear 265/35ZR18
Tire Pressures:
Front: 36psi
Rear: 44psi
Ran a calculator comparing what you have to mine and looks like the total diameter is different:
Old 05-17-2022, 12:07 AM
SealG996
SealG996's Avatar
Originally Posted by jimkuhr
It seems like my speedometer is reading between 3 and 5 MPH on the high side (i.e. showing faster than I'm actually going). This is based on readings from a couple of those radar signs that show your speed. Does anyone know if the dealers can do a good job of calibrating the speedometer? Any other thoughts on calibration?
Drive on!
Jim
I went to 285/35/18 Michelin Pilot. Theoretically this would case speedometer error, cause traction control problems etc. The increase in diameter from 265/35/18 (Achilles dealer fit) has only reduced Sperdometer error, compared with GPS not eliminated it. The speedomter remains optimistic.
Quick Reply: Speedometer calibration?
