996 Forum 1999-2005
Removal/Replacement of CD storage in center console
Old 06-14-2006, 10:22 AM
gota911
Newbies Hospitality Director
gota911's Avatar
Edward - I thought it was probably something like that, but I couldn't "place" the phrase or quote.
Old 05-20-2014, 08:31 AM
Gr4t
Gr4t's Avatar
Sorry to drag up an old thread but I'm looking to fit one of these and can't find any help anywhere, I currently have nothing there and it's just the carpet.... Any help would be greatly received
Old 05-20-2014, 08:47 AM
dgjks6
dgjks6's Avatar
Do a search for center console delete. It was an option or a DIY.
Then just reverse the process - I assume.
Old 05-20-2014, 09:20 AM
Colorado Bob
Colorado Bob's Avatar
If you don’t want your cup holder above your electronics you can download this file http://www.thingiverse.com/thing:292359 and have someone print it out on a 3D printer. I designed it for my ’99 but it should fit any model with a console ashtray. Remove ashtray 2.3 seconds, insert cup holder 2.1 seconds.
If you want to move your climate control down as shown in the image you will need this kit from Suncoast parts. http://www.suncoastparts.com/product..._Code=996intup
This is an extra storage bin that fits perfectly into the space where the CD holder is. http://www.suncoastparts.com/product..._Code=996intup
Old 06-22-2017, 12:45 AM
professorman
professorman's Avatar
I haven't found any pics of anyone who relocated the cup holders to the lower section where the Cd tray was. The cup holders look larger than the CD tray. Does it definitely fit in that location fine?
Old 06-22-2017, 04:50 AM
dan_189
dan_189's Avatar
I actually don't think that's even possible and most likely why there are no images of it. You've also bumped a 10+ year old thread FYI
Old 06-22-2017, 08:15 AM
professorman
I found a tread on 6peedonline where one guy relocate the cup holder.
https://www.6speedonline.com/forums/...tml?styleid=26
BTW, the 10+ year tread actually had great information for my 10+ year car, which is better than starting a new tread about the exact same topic.
Originally Posted by Steve Jarvis
Here's my setup. It's a Kenwood DNX9990HD head unit with factory cup holders mounted in the lower console.
I used the cage that came with the headunit, bought the wiring harness and antenna adapter on ebay and made the face plate.
The faceplate is a 1/4" thick piece of plexiglass with the back side painted black. This give the faceplate a deep high gloss finish similar to the head unit (hard to tell in the picture).
The cup holders are not complete as I have a new cup holder surround to trim. My Dremel battery went dead when trimming the cup holder surround and I tried something else. Bad idea, as I basically "hacked up" the cup holder surround.
FYI getting the cup holder to work like this is a royal PITA. The stock cup holder doesn't even come close to fitting, so it's definitely a custom project. You will need to significantly cut down the cup holder chassis, its surround and also trim the opening in the console slightly.
When that's complete you will need to build a frame to mount the cup holder chassis to and attach it to the console. After this is complete, you will have a functional cup holder, but not a great cup holder. It's not only shallow, but now at an angle. Basically you undertake the cup holder project at your own risk.
Later, Steve
Old 06-22-2017, 08:19 AM
dan_189
dan_189's Avatar
Assuming you mean thread and not tread...
Okay I see, so then they can be moved on a MK1.
Good luck with the project
Old 07-23-2020, 08:13 PM
Bozbomber
Bozbomber's Avatar
Colorado Bob May I know what is this square things on the top left of your center console picture for? I have the same head unit and switch as yours but i do not know what is the switch for.
Old 07-23-2020, 08:36 PM
dan_189
dan_189's Avatar
Looks like it might be a microphone rather than a switch?
Old 07-23-2020, 08:53 PM
Bozbomber
Bozbomber's Avatar
I thought the microphone is the one on the left which i have it as well, no?
Old 07-23-2020, 09:37 PM
dan_189
dan_189's Avatar
Yes you're right - couldn't see that on my phone - maybe a call answer button? Have you read the manual for the headunit?
Old 07-23-2020, 11:49 PM
Bozbomber
Bozbomber's Avatar
Yep, you are right! I googled for a installation manual and that button is for call answer.
Old 07-27-2020, 06:02 PM
craigmakes321
craigmakes321's Avatar
I have a perfect cd holder I just removed from my '99 C2 if anyone is interested in buying it. PM me
Never saw the replacement storage tray (996-552-243-01) for under $60 at a dealer....
Old 07-28-2020, 08:38 AM
frisbee91
frisbee91's Avatar
Ooh. I have a perfect cassette holder that goes in the storage tray location! PM me!!
bnh996 (03-04-2022)
Quick Reply: Removal/Replacement of CD storage in center console
