replacement bushings for removing ssk?
I did a search and came up with 1 thread that didn't say too much. Anyone know where I can get a set of replacement bushings so I can remove my ssk and install the old one? Let me know where and how much stock or otherwise. Thanks Sean
Newbies Hospitality Director
Check out Post #4 in this thread. Tool Pants has supplier a pic that shows the stock OEM shifter using the B&M aluminum bushings. Obviously, that would not allow you to have all the necessary parts available for the SSK if you wanted to sell it or transfer it to another car.
Post # 6 shoes a pic of a recently purchased Porsche SSK, and it shows some new OEM plastic bushings. I don't know if the OEM bushings are available separately or not.
https://rennlist.com/forums/996-forum/301903-b-and-m-short-shifter.html
Hope this helps.
Hope this helps.
