996 Forum 1999-2005
Will this effect my ride? HELP!!
Old 01-20-2007, 11:28 PM
911mz
911mz's Avatar
Default Will this effect my ride? HELP!!
Ok Long story short, my right rear tires is 285/30/18 BUT my left rear tire is 285/35/18 do you guys think it will effect my ride or suspension? front are fine.
Old 01-20-2007, 11:41 PM
Ray S
Ironman 140.6
Ray S's Avatar
You realize that the diameter of your rear differs by 4.3%? In other words if you are traveling at an indicated 100 mph one of your wheels will rotating at 100 mph and the other rear will be traveling at 95.46 mph (or 104.54 mph).
I would correct the problem if I were you.
Old 01-21-2007, 12:21 AM
Dave Howerdel
Dave Howerdel's Avatar
Aside from how your car tracks down the road, handles on the road, or stresses your current alignment(or lack thereof)...not to mention tire wear or weight balance through dynamic direction changes, then, no.
Just out of curiousity, which side is the 35? If it's the right, perhaps Your car might make a good nascar candidate.
Honestly, It's a question with an obvious answer. If you had a $300 85 chrysler lebaron daily winter beater, you might not give a ****, but c'mon, think about it.
Old 01-21-2007, 01:26 AM
kromdom
kromdom's Avatar
curious how you ended up with "mismatched" rear tires???
Old 01-21-2007, 01:27 AM
911mz
911mz's Avatar
my mistake, I know
Old 01-21-2007, 01:34 AM
kromdom
kromdom's Avatar
my mistake, I know
hope you get it fixed soon!!
Old 01-21-2007, 11:01 AM
MechanicalEng
MechanicalEng's Avatar
that will put a lot of stress on your differential... fix it now!
Old 01-21-2007, 11:24 AM
Drmark
Drmark's Avatar
You are joking.....
Old 01-21-2007, 11:28 AM
jcb-memphis
jcb-memphis's Avatar
Ditto.
JB
Old 01-21-2007, 04:08 PM
Nicolaasdb
Nicolaasdb's Avatar
I got an 18inch rim on the left rear and a 19inch on the right rear...in front I got a 17 inch on the right and a 20 in on the left.....do you think this will effect my ride????
Old 01-22-2007, 12:06 AM
VGM911
VGM911's Avatar
It all depends.....are the wheels on the driver's side of the car turning counter clockwise?
Old 01-22-2007, 12:35 AM
programmatore
programmatore's Avatar
It will most certainly affect your ride. Mismatched tires will have a negative effect on your ride.
affect
effect
Old 01-22-2007, 01:17 AM
911mz
911mz's Avatar
thank you for your input really appreciated.
Old 01-22-2007, 02:31 AM
Porsche_Smile
Porsche_Smile's Avatar
fix it....
Old 01-22-2007, 07:48 AM
Carrera Mike
Carrera Mike's Avatar
Fix it asap! Your PSM will go crazy at high speed seing one wheel going slower than the rest.
Quick Reply: Will this effect my ride? HELP!!
